Octane for H18 ?
Forums: Octane for H18 ?
Houdini Integrated Plugin
Octane for H18 ?
Postby AlexSudnikov » Sat Feb 08, 2020 12:51 pm
AlexSudnikov Sat Feb 08, 2020 12:51 pm
Hey everyone!
Just wondering if there is any chance to see new plugin for new Houdini 18.
Plugin for 17.5 doesn't work...as expected :)
Thx.
AlexSudnikov
Re: Octane for H18 ?
Postby galleon27 » Sat Feb 08, 2020 7:23 pm
galleon27 Sat Feb 08, 2020 7:23 pm
Win 10 64bit // GTX 1080 + GTX 1080 Ti // i7 4790k // 16GB // SideFX Houdini // C4D
galleon27
Postby AlexSudnikov » Sun Feb 09, 2020 8:03 am
AlexSudnikov Sun Feb 09, 2020 8:03 am
Thx man !
Unfortunately i can't install it :cry: ( tried different versions)...keep getting this error
"Couldn't find 'SI_ColorEditor.ui' for reading. Looked in:
C:/Otoy/Octane_2019.1.5.0_Houdini_18.0.287_Win64/config/Applications$/config/Applications"
Found the same issues on the forum but somehow mentioned soludtions didn't work out for me...
viewtopic.php?f=101&t=71227
It's probably has smth, to do with env. variables but...dunno what exactly is missing.
Any tips are greatly appreciated ! Thx!)
AlexSudnikov
Postby juanjgon » Sun Feb 09, 2020 5:41 pm
juanjgon Sun Feb 09, 2020 5:41 pm
This is a mistake in the houdini.env file HOUDINI_PATH variable for sure, probably related to a wrong quotes character or something like that. If you want to attach your file here, I could take a look at it.
juanjgon
Postby AlexSudnikov » Mon Feb 10, 2020 8:30 am
AlexSudnikov Mon Feb 10, 2020 8:30 am
Hi , thx for the reply ! :)
Here is my houdini.env :
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup.  They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
#    VAR = VALUE
# Values may be quoted
#    VAR = "VALUE"
# Values may be empty
#    VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_DSO_ERROR = 2
PATH = "C:\Otoy\Octane_2019.1.5.0_Houdini_18.0.287_Win64\bin;$PATH"
HOUDINI_PATH = "C:\Otoy\Octane_2019.1.5.0_Houdini_18.0.287_Win64;$"
The path is 100% correct...
https://prnt.sc/r01wnl
Thx)
AlexSudnikov
Postby juanjgon » Mon Feb 10, 2020 3:00 pm
juanjgon Mon Feb 10, 2020 3:00 pm
Sorry, the problem is that the path append character for the HOUDINI_PATH variable is & not $
HOUDINI_PATH = "C:\Otoy\Octane_2019.1.5.0_Houdini_18.0.287_Win64;&"
juanjgon
Postby AlexSudnikov » Mon Feb 10, 2020 3:41 pm
AlexSudnikov Mon Feb 10, 2020 3:41 pm
Thank you very much Juanjo ! It works now ! :)
AlexSudnikov
Return to Houdini
Thu Jul 02, 2020 9:16 am [ UTC ]
