Octane vopnet and subinput/subouput
Forums: Octane vopnet and subinput/subouput
Houdini Integrated Plugin
Postby blobbybarack » Fri Nov 29, 2019 2:49 pm
blobbybarack Fri Nov 29, 2019 2:49 pm
How do you/can you work with subinput/suboutoput at mat context top level ?
Maybe i make a confusion about it.
Can i construct a similar structure as subnet inside octane vop node but at an higher level in mat context ?
As an exemple.
>Two different octane vop node at top level .
>Each one are differents (projection, material or whatever...)
>an octane subnet node with some texture jamming...like a complex noise+osl+texture mix or whatever...at the top level in mat context too
Can i feed my 2 shaders with this top level octane subnet ?
It could be super handy for heavy scenes when differents shaders calls the same texture again and again. It could save a lot of VRAM too as you will call the same texture only once.
Please enlighten me, I can't figure it out if you just can't do this or if i miss something here.
blobbybarack
Re: Octane vopnet and subinput/subouput
Postby juanjgon » Fri Nov 29, 2019 6:20 pm
juanjgon Fri Nov 29, 2019 6:20 pm
Currently, the Octane vopnet doesn't have inputs or outputs, but you could use the PluginTools->ShaderMerge node to link any vop node or node tree to the nodes inside your vopnet.
juanjgon
Postby blobbybarack » Fri Nov 29, 2019 7:01 pm
blobbybarack Fri Nov 29, 2019 7:01 pm
Whaou I was not aware about the ShaderMerge.
This is even more usefull than what i was expecting. Great. This is what i need !
Thank you !
blobbybarack
Return to Houdini
Who is online
Users browsing this forum: No registered users and 18 guests
Thu Apr 25, 2024 4:42 pm [ UTC ]
