artifact when i use reflection
Forums: artifact when i use reflection
Houdini Integrated Plugin
Postby supermac » Thu Aug 29, 2019 2:43 pm
supermac Thu Aug 29, 2019 2:43 pm
Hi everyone,
sorry for my English.
I have a problem.
i need a Watch render to do.
But i have Always big artifacts on my geometry if i use reflection.
someone have an idea?
if you turn the camera, you would see where is Always artifact.
And if i change cusp angle, there is Always artifact somewhere.
i attach my file if someone will help me.
i know perhaps my file is not perfect, but it's possible to this point?
this file come from SolidWorks and it's a .stl file.
Thank you for you help.
Best regards
demo.zip
file with hip file, bgeo file and hrd image
(6.38 MiB) Downloaded 122 times
supermac
Re: artifact when i use reflection
Postby supermac » Tue Sep 03, 2019 12:42 pm
supermac Tue Sep 03, 2019 12:42 pm
hi,
no idea?
supermac
Postby juanjgon » Wed Sep 04, 2019 9:06 am
juanjgon Wed Sep 04, 2019 9:06 am
Sorry for the late reply, I'm in a short vacation break. I'm not sure why you get these artifacts in this object, but it seems related to the object itself because as you can see in the attached images, I get the same artifacts in the viewports or in Mantra. I tried to improve the mesh topology using the clean sop and so on, but without luck so far. I suspect that the problem can be related to the bunch of small and thin polygons available in the mesh, but I'm not sure ... perhaps you could ask SideFX about this issue.
juanjgon
Postby supermac » Wed Sep 04, 2019 12:30 pm
supermac Wed Sep 04, 2019 12:30 pm
hi Juanjo,
thank you for your answer.
I ear that solid work export are not good.. but i don't know.
I will try with sidefx.
Thank you again.
Best regards.
supermac
Return to Houdini
Users browsing this forum: No registered users and 23 guests
Sat Apr 20, 2024 2:17 am [ UTC ]
