how to export C4D octane materials to Houdini?
Forums: how to export C4D octane materials to Houdini?
Houdini Integrated Plugin
Postby Edison_1 » Thu Apr 11, 2019 6:52 pm
Edison_1 Thu Apr 11, 2019 6:52 pm
I have a problem with tansfering materials between C4D and Houdini using octane .
Can solve it by using .orbx?
or orthers?
if use orbx, how to import it to Houdini and export it from C4D ?
best wish,
Edison Sean
Edison_1
Re: how to export C4D octane materials to Houdini?
Postby juanjgon » Thu Apr 11, 2019 8:21 pm
juanjgon Thu Apr 11, 2019 8:21 pm
If you only want to export materials, you should use the LocalDB feature, exporting the materials from C4D to the LocalDB and importing them using this feature in the Houdini plugin. The LocalDB directory configuration must be the same in both packages.
juanjgon
Postby Edison_1 » Fri Apr 12, 2019 5:33 am
Edison_1 Fri Apr 12, 2019 5:33 am
juanjgon wrote:Hi,
Thanks,Juanjo.
Your advice is a nice plan.
But it was difficult to close the Houdini scenes after import a localDB/liveDB material,
even I saved it.
I have to end process.
Houdini:17.5.173
Octance:2018.1.0.7
Edison
Edison_1
Postby juanjgon » Fri Apr 12, 2019 9:21 am
juanjgon Fri Apr 12, 2019 9:21 am
So do you say that Houdini freezes after importing a LiveDB material? Here this feature seems to work fine. Are you working on Windows?
juanjgon
Postby Edison_1 » Fri Apr 12, 2019 1:32 pm
Edison_1 Fri Apr 12, 2019 1:32 pm
juanjgon wrote:So do you say that Houdini freezes after importing a LiveDB material? Here this feature seems to work fine. Are you working on Windows?
I said the Houdini can't be exited after importing a LiveDB material.
It's freezed when I exit Houdini program.
It can be worked after importing a LiveDB material.
Edison_1
Return to Houdini
Who is online
Users browsing this forum: No registered users and 8 guests
Fri Apr 19, 2024 8:32 pm [ UTC ]
