NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Forums: NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Re: URGENT: NVIDIA 418.81 breaks Octane - don't update yet!
Postby Seun116_1 » Fri Feb 22, 2019 3:54 pm
Seun116_1 Fri Feb 22, 2019 3:54 pm
New Nvidia update finally works with Octane!
Seun116_1
Postby jwlovell » Fri Feb 22, 2019 5:19 pm
jwlovell Fri Feb 22, 2019 5:19 pm
Goldorak wrote:NVIDIA 418.81 driver (Feb. 4th) doesn't work with Octane - please don't update yet! We are working with NVIDIA to fix ASAP. We need to recompile Octane 4/2018.1+ to work with this driver version, and will post an update to this thread once that is done and confirmed working. Thank you!
If you have updated to this driver, here is how to revert: viewtopic.php?p=356426#p356426
419 is out as of today. Hope that fixes this. It's breaking my other iray apps
jwlovell
Postby DoctorJellybean » Fri Feb 22, 2019 5:45 pm
DoctorJellybean Fri Feb 22, 2019 5:45 pm
Hmm, the 419.17 update doesn't seem to work for me (1080 Ti and DAZ Studio Plugin). It works when reverting back to 417.71
DoctorJellybean
Postby DoctorJellybean » Fri Feb 22, 2019 6:15 pm
DoctorJellybean Fri Feb 22, 2019 6:15 pm
I didn't see that there is a DAZ Studio plugin update (4.02.1.44), the updated NVIDIA drivers do work with that installed.
DoctorJellybean
Postby TRRazor » Fri Feb 22, 2019 8:20 pm
TRRazor Fri Feb 22, 2019 8:20 pm
Sorry, but no, it doesn't.
I just updated to 419.17 and get the following error, upon opening the render viewport:
21:04:11.494: +++++ Plugin running.
21:18:46.133: CUDA error 999 on device 0: unknown error
21:18:46.133: -> failed to link file
21:18:46.133: device 0: failed to load OSL shader code: error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
21:18:46.133: device 0: failed to compile module 0
21:18:46.138: CUDA error 999 on device 1: unknown error
21:18:46.138: -> failed to link file
21:18:46.139: device 1: failed to load OSL shader code: error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
21:18:46.139: device 1: failed to compile module 0
21:18:46.157: Render engine failure occured! (WARNING)
21:18:53.728: Render engine failure occured! (WARNING)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
TRRazor
Postby DoctorJellybean » Fri Feb 22, 2019 8:24 pm
DoctorJellybean Fri Feb 22, 2019 8:24 pm
Just updated to 419.17 and get the following error, upon opening the render viewport:
Did you update the DS plugin (4.02.1.44)?
DoctorJellybean
Postby cadmiumred » Fri Feb 22, 2019 9:50 pm
cadmiumred Fri Feb 22, 2019 9:50 pm
I'm experiencing this same error using OctaneRender 4.01.1 Standalone. Today's Nvidia update (419.17) appears to not fix the issue.
cadmiumred
Postby mojave » Fri Feb 22, 2019 10:11 pm
mojave Fri Feb 22, 2019 10:11 pm
Hi everyone,
Just letting you all know that the latest driver 419.17 fixes the issue with Octane that the series 418 used to have.
Please make sure your plugin or standalone is using the following versions of the Octane core:
- Stable 4.02 or newer (there will also be a new v3 release soon)
- Experimental 2018.1 RC2 or newer.
Thank you.
mojave
Re: NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Postby hpeskobar » Sat Feb 23, 2019 11:05 am
hpeskobar Sat Feb 23, 2019 11:05 am
417 work fine then I update to 418 fail. waited 7 days ... gave up re install 417 took forever . octane work fine....
updated to 419.17
Now I get this................. ( c4d)
Started logging on 23.02.19 04:54:49
OctaneRender Studio 4.01.1 (4010100)
1hr Later im back to 417 and everything oks fine now.
but STILL NO FIX
hpeskobar
Postby nuno1980 » Sat Feb 23, 2019 11:40 am
nuno1980 Sat Feb 23, 2019 11:40 am
hpeskobar wrote:417 work fine then I update to 418 fail. waited 7 days ... gave up re install 417 took forever . octane work fine....
updated to 419.17
but STILL NO FIX
You have OR v4.01.1 but @Mojave said minimum v4.02 or newer version only... loool
NOTE: I'm sorry for bad english due to mute ;)
i7-12700KF
2x16GB RAM@DDR4-3600
MSI PRO Z690-A DDR4
Zotac GF RTX 4090 NEW! <3 :mrgreen:
SSDs OCZ RD400 0.5TB and Crucial 2TB SATA3
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
CRT 21" Sony E530 :D
nuno1980
PreviousNext
Return to Development Build Releases
Users browsing this forum: No registered users and 13 guests
Wed Apr 24, 2024 3:44 am [ UTC ]
