Got a incorrect rending in a big scene
Forums: Got a incorrect rending in a big scene
Houdini Integrated Plugin
Postby Edison_1 » Fri Nov 02, 2018 3:07 am
Edison_1 Fri Nov 02, 2018 3:07 am
I got a incorrect rending when I tried to scale my object bigger
(because I need to get correct scale of the scene)
I have tried to use different plugin version in houdini(16.5&17) and getting the same result
Edison_1
Re: Got a incorrect rending in a big scene
Postby juanjgon » Fri Nov 02, 2018 9:48 am
juanjgon Fri Nov 02, 2018 9:48 am
In the kernel nodes, or in the render target HDA kernel tab you have a "Ray Epsilon" parameter that should help with these kinds of issues. Be aware that Octane works with single precision floating maths, so if the scene is too big or too small, tunning this parameter could be needed to remove the rendering artifacts.
Hope it helps,
juanjgon
Postby Edison_1 » Fri Nov 02, 2018 11:36 am
Edison_1 Fri Nov 02, 2018 11:36 am
juanjgon wrote:Hi,
Hope it helps,
Hello,
Thank you for your response.
It solve the problem perfactly
Thank you!
Edison_1
Return to Houdini
Thu Oct 01, 2020 8:14 am [ UTC ]
