The best way to manage Octane materials for later reuse?
Forums: The best way to manage Octane materials for later reuse?
Houdini Integrated Plugin
Postby JakubRupa » Fri Feb 02, 2018 3:36 pm
JakubRupa Fri Feb 02, 2018 3:36 pm
What is the "proper" way?
I know that there is something called LocalDB, but how to use it?
Or maybe there is a better way?
MODO 902 SP1 + Octane 3.0.4 | Windows 10 64bit, i7 4790K, 32GB | 2 x Asus Strix GeForce GTX970 4GB
[url=be.net/JakubRupa/]Behance[/url]
JakubRupa
Re: The best way to manage Octane materials for later reuse?
Postby juanjgon » Sat Feb 03, 2018 11:52 am
juanjgon Sat Feb 03, 2018 11:52 am
If you want to reuse materials always inside Houdini, the best solution is to build HDAs with the Octane VOP nodes that you need to build the material embedded inside. The important parameters needed to control de material can be exposed in the top HDA node, and these nodes can be used over multiple projects from a source library.
http://www.sidefx.com/docs/houdini/assets/index.html
Hope this helps,
juanjgon
Postby JakubRupa » Mon Feb 05, 2018 1:03 pm
JakubRupa Mon Feb 05, 2018 1:03 pm
Thanks, Juanjgon.
It is possible maybe to save textures inside HDAs to use with Octane?
JakubRupa
Postby juanjgon » Mon Feb 05, 2018 9:28 pm
juanjgon Mon Feb 05, 2018 9:28 pm
Yes, you can include texture maps inside the HDAs. This is a brief introduction about how to work with them:
https://dimitriscg.wordpress.com/2016/1 ... s-in-hdas/
juanjgon
Postby JakubRupa » Tue Feb 06, 2018 8:17 am
JakubRupa Tue Feb 06, 2018 8:17 am
That's great, thanks Juanjgon!
JakubRupa
Return to Houdini
Users browsing this forum: No registered users and 11 guests
Sat Apr 20, 2024 12:10 am [ UTC ]
