Newbie MacOSX Instal Question
Forums: Newbie MacOSX Instal Question
Houdini Integrated Plugin
Postby p3taoctane » Tue Dec 05, 2017 9:21 pm
p3taoctane Tue Dec 05, 2017 9:21 pm
This is probably a basic question....
In the manual is says:
.. copy the resulting uncompressed files somewhere.
I unzipped copied the folder with the plugin contents called... Octane_3.08.0.0_Houdini_16.5.268_OSX
to
/Users/XXX/Library/Preferences/Houdini/16.5
so I had...
/Users/XXX/Library/Preferences/Houdini/16.5/Octane_3.08.0.0_Houdini_16.5.268_OSX
I then edited my
/Users/XXX/Library/Preferences/Houdini/16.5/houdini.env
by adding:
HOUDINI_PATH = //Users/XXX/Library/Preferences/Houdini/16.5/Octane_3.08.0.0_Houdini_16.5.268_OSX;&
To the env file
Is that correct or should it be.....
HOUDINI_PATH = /Users/XXX/Application/OctaneRender 3.08_test6.app/Contents/MacOS/octane;&
OR
HOUDINI_PATH = /path/to/octane;/Users/XXX/Application/OctaneRender 3.08_test6.app/Contents/MacOS/octane;
OR
HOUDINI_PATH = /path/to/octane;/Users/XXX/Library/Preferences/Houdini/16.5/Octane_3.08.0.0_Houdini_16.5.268_OSX
Sorry for weird question
p3taoctane
Re: Newbie MacOSX Instal Question
Postby juanjgon » Tue Dec 05, 2017 11:16 pm
juanjgon Tue Dec 05, 2017 11:16 pm
I'm not sure if it is a good idea copy any plugin folder inside the Houdini preferences directory, but, well, at first glance I suppose that this is not going to be a problem.
So, if you have your plugin folder at /Users/XXX/Library/Preferences/Houdini/16.5/Octane_3.08.0.0_Houdini_16.5.268_OSX your houdini.env file should be:
HOUDINI_DSO_ERROR = 2
HOUDINI_PATH = "/Users/XXX/Library/Preferences/Houdini/16.5/Octane_3.08.0.0_Houdini_16.5.268_OSX;&"
If this doesn't work, please let me know.
juanjgon
Postby p3taoctane » Wed Dec 06, 2017 12:50 am
p3taoctane Wed Dec 06, 2017 12:50 am
Yep that did it thanks
I will move it to something less suspect.
Appreciate the help
Peter
p3taoctane
Return to Houdini
Users browsing this forum: No registered users and 15 guests
Thu Apr 25, 2024 9:16 am [ UTC ]
