Heightfield
Forums: Heightfield
Houdini Integrated Plugin
Heightfield
Postby videlam » Thu Nov 23, 2017 10:15 pm
videlam Thu Nov 23, 2017 10:15 pm
Hi, I made a mountain in Houdini, I tried to render it.
I know the attributes is not recognised yet, so I tried to export with COP2NET/SOP/ROP to get the height map and put it on a grid with a displacement.
the problem is the map is RAW with only White and black, nothing in between. Mantra support the raw heightmap but not octane.
What I'm missing?
videlam
Re: Heightfield
Postby juanjgon » Fri Nov 24, 2017 9:55 am
juanjgon Fri Nov 24, 2017 9:55 am
Well, if the map only has black and white values I can't figure how it could be used for the mountain displacement. If you want to share the scene, I could take a look at it.
Also, remember that you could render the Houdini mountain objects adding a Convert SOP to convert it to a mesh object.
juanjgon
Re: Heightfield
Postby videlam » Fri Nov 24, 2017 1:58 pm
videlam Fri Nov 24, 2017 1:58 pm
Hi thanks for the answer.
It's a RAW height map, you can only see B/W but they have a tons of informations between them, Mantra remap it automatically but not octane.
Converting in mesh, is not the solution to get the debris or the flow and their masks.
I finally found the solution, to convert with HeightField output node.
I had to put the height on each color with auto remap, and duplicate the node for each map (height, debris, flow, mask)
videlam
Return to Houdini
Users browsing this forum: No registered users and 13 guests
Wed Apr 24, 2024 7:00 am [ UTC ]
