invalid node type error
Forums: invalid node type error
Houdini Integrated Plugin
Postby nathanapffel » Mon Oct 16, 2017 9:54 pm
nathanapffel Mon Oct 16, 2017 9:54 pm
I'm on linux. I just reinstalled octane with houdini16.0.736 and its now giving an error. it looks like this:
The attempted operation failed.
Traceback (most recent call last):
File "Add_Octane_ROP", line 1, in <module>
File "/opt/hfs16.0.736/houdini/python2.7libs/roptoolutils.py", line 9, in createRenderNode
rop = hou.node('/out').createNode(rop_type, exact_type_name=True)
File "/opt/hfs16.0.736/houdini/python2.7libs/houpythonportion.py", line 1257, in decorator
return func(*args, **kwargs)
File "/opt/hfs16.0.736/houdini/python2.7libs/hou.py", line 6707, in createNode
return _hou.Node_createNode(*args, **kwargs)
OperationFailed: The attempted operation failed.
Invalid node type name
I extracted the octane files to /home/nathan/octane
my houdini file looks has there lines:
HOUDINI_DSO_ERROR = 2
PATH = "/usr/redshift/bin;/home/nathan/octane/bin:$PATH"
HOUDINI_PATH = "/usr/redshift/redshift4houdini/16.0.705;/home/nathan/octane;&"
redshift is working althought I got this error for redshift the other day. And was given the suggestion to revert back to a previous version of my nvidia drivers. I have now tried nvida-387, nvida-384, and nvida-381 all with the same error.
Is the .env file not correct? I installed my nvida drivers with the linux mint driver manager so i assume they are installed correctly plus redshift seems to be fine.
what should i do try next.
thanks,
nathanapffel
Re: invalid node type error
Postby juanjgon » Mon Oct 16, 2017 11:02 pm
juanjgon Mon Oct 16, 2017 11:02 pm
Hi Nathan,
I've replied to your email sent to the Otoy support. If you don't receive the reply, please let me know.
juanjgon
Postby nathanapffel » Tue Oct 17, 2017 4:02 am
nathanapffel Tue Oct 17, 2017 4:02 am
Juanjo,
Thank you very much for your prompt response. After messing around with the path and installing different houdini versions and octane builds with no luck. I installed the freeglut lib that you suggested on my linux mint distro, and bingo! That did it. I would never have known. thank you for helping me figure it out.
nathanapffel
Postby nathanapffel » Tue Oct 17, 2017 1:16 pm
nathanapffel Tue Oct 17, 2017 1:16 pm
Juanjo,
nathanapffel
Return to Houdini
Users browsing this forum: No registered users and 16 guests
Thu Apr 25, 2024 7:40 am [ UTC ]
