Setting lights color from color palette
Forums: Setting lights color from color palette
Houdini Integrated Plugin
Postby FahadA92 » Fri Jan 13, 2017 8:42 am
FahadA92 Fri Jan 13, 2017 8:42 am
Hello,
I have a color palette that I'd like to use to light my scene. I've tried all methods, and it seems the only way to set color in octane is with temperature but I only have the rgb values from Houdini (see attachment). I even tried changing the diffuse color in the emission material but that didn't help.
Windows 8.1, GTX 970 EVGA SC, i7 4790k, 32GB RAM
FahadA92
Re: Setting lights color from color palette
Postby juanjgon » Fri Jan 13, 2017 9:01 am
juanjgon Fri Jan 13, 2017 9:01 am
If you are lighting your scene using objects with the Octane OBJ spare parameters, you only need to set the Emission type to "Color/Texture" and set the color using the Color RGB parameter. The same happens if you are using a custom emission material, you must use the Texture Emission node.
juanjgon
Postby FahadA92 » Fri Jan 13, 2017 4:30 pm
FahadA92 Fri Jan 13, 2017 4:30 pm
Thank you prompt reply. I used the Octane OBJ spare parameters, and it worked! I don't know why it didn't before, or how I missed it.
Thank you again.
FahadA92
Return to Houdini
Fri Apr 03, 2020 11:44 pm [ UTC ]
