by juanjgon » Fri Aug 26, 2016 9:17 am
juanjgon
Yes, I think that the Octane API supports the subdivision edge creasing data in the OpenSUBd meshes, but the plugin doesn't support this feature yet. I'll try to add this feature, but meanwhile remember that the plugin should be able to render the Houdini subdivision surfaces without problems. The extraction time could be longer, but the compilation time in Octane will be shorter, and finally the GPU memory used will be the same.
