Octane doesn't work with Afanasy network rendering
Forums: Octane doesn't work with Afanasy network rendering
Houdini Integrated Plugin
Postby Evgen » Wed Jun 08, 2016 2:39 pm
Evgen Wed Jun 08, 2016 2:39 pm
Hello,
I have a bug with rendering with octane with afanasy rendering system. http://cgru.info/afanasy/afanasy
As result - all frames are saving in the first frame file "Output_0001.exr" But actually File name path in octane rop is "Output_$F4.exr"
But unfortunately it doesn't work for multiple frames at all.
I am ready to make testings and all other things to solve it becase Afanasy is the best network render management and its free and used by a lot of people.
Evgen
Re: Octane doesn't work with Afanasy network rendering
Postby juanjgon » Wed Jun 08, 2016 4:26 pm
juanjgon Wed Jun 08, 2016 4:26 pm
Probably the problem is that the render manager doesn't understand the Octane ROP node parameters, that are not the same than Mantra. How it works, with scripts?
For example, the Octane ROP node file name/prefix parameter is "HO_img_fileName", while in Mantra is "vm_picture". If this is the only problem with your render manager, you could try to add a spare parameter to the Octane ROP node named "vm_picture" linked to the "HO_img_fileName" to see if Afanasy can get the file name.
Perhaps this is not the only one problem, but can be a starting point.
juanjgon
Postby Evgen » Wed Jun 08, 2016 6:47 pm
Evgen Wed Jun 08, 2016 6:47 pm
Juanjo, thanks for advice.
That could help.
I will try it in a few hours and let you know the result.
Evgen
Return to Houdini
Mon Mar 30, 2020 8:16 am [ UTC ]
