How to mix two displacement maps?
Forums: How to mix two displacement maps?
Houdini Integrated Plugin
Re: How to mix two displacement maps?
Postby galleon27 » Tue Jul 05, 2022 10:10 am
galleon27 Tue Jul 05, 2022 10:10 am
Looked at your file. There are a few things you need to know. Displacement maps are data maps so the color space should be set to Non-color Data. Since they are data maps, you should avoid using jpegs since jpegs are 8bit. For best results, always use 32bit images for displacements. Mid-level for all quixel displacement maps should be set to 0.5.
For some reason, using attributes for mixing doesn't work. Maybe it's a bug or some limitation. Maybe Juanjo could check that out.
Using procedurals to mix works fine.
Mix_Displacements.zip
(5.78 MiB) Downloaded 78 times
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Postby Admin_KeenSWH » Tue Jul 05, 2022 11:35 am
Admin_KeenSWH Tue Jul 05, 2022 11:35 am
galleon27 wrote:Looked at your file. There are a few things you need to know. Displacement maps are data maps so the color space should be set to Non-color Data. Since they are data maps, you should avoid using jpegs since jpegs are 8bit. For best results, always use 32bit images for displacements. Mid-level for all quixel displacement maps should be set to 0.5.
Thanks for your reply,
Yes of course I did try EXR 32bit versions of those maps too - same problem - they just don't mix at all.
Note that even if I disable the displacement texture that should be in the black area - the first displacement texture is still displacing the surface but in some weird way:
MY CONFIG:
OS: Win 10
Video Card: 2070 RTX
VRam: 8Gb
Geforce Driver: 516.69
OctaneRender Standalone 2021.1.4
OctaneRender Houdini plugin version 2021.1.5.0 (May 18 2022)
Houdini FX Version 19.0.622
Admin_KeenSWH
Postby Admin_KeenSWH » Tue Jul 05, 2022 6:55 pm
Admin_KeenSWH Tue Jul 05, 2022 6:55 pm
I really need help with this guys, I know in Arnold it is possible to mix two displacement maps but I don't want to switch to Arnold only because of this tiny feature really.
If this feature is not existing in Octane yet - would it be possible to include it into a wishlist you guys might have?
MY CONFIG:
OS: Win 10
VRam: 8Gb
Admin_KeenSWH
Postby juanjgon » Wed Jul 06, 2022 8:23 am
juanjgon Wed Jul 06, 2022 8:23 am
galleon27 wrote:For some reason, using attributes for mixing doesn't work. Maybe it's a bug or some limitation. Maybe Juanjo could check that out.
This is a known core limitation.
juanjgon
Postby Admin_KeenSWH » Wed Jul 06, 2022 12:48 pm
Admin_KeenSWH Wed Jul 06, 2022 12:48 pm
juanjgon wrote:This is a known core limitation.
Thanks for your feedback guys, I appreciate it. So the way I understood currently mixing two displacement maps by attribute value is not possible - no problem. But mixing by some procedural noise - does work.
Could you suggest some workaround to this? For example in C4D there is a workaround - to feed both textures (mixed by attribute) to a Baking Texture Node first, bake both mixed textures into one, and then feed that baked result into Displacement Node. I tried that in Houdini but it didn't work either unfortunately. So I was thinking maybe there is some other Houdini-specific workaround for this? Is it possible to convert attribute float values to some grayscale map and feed it as a mix?
MY CONFIG:
OS: Win 10
VRam: 8Gb
Admin_KeenSWH
Postby galleon27 » Wed Jul 06, 2022 3:42 pm
galleon27 Wed Jul 06, 2022 3:42 pm
Here you go. I've attached the file.
You can just import attributes into COPs and use that as a texture.
Cheers.
(5.79 MiB) Downloaded 86 times
galleon27
Postby Admin_KeenSWH » Wed Jul 06, 2022 4:51 pm
Admin_KeenSWH Wed Jul 06, 2022 4:51 pm
galleon27 wrote:Here you go. I've attached the file.
Cheers.
Oh wow, that's definitely a solution! Thanks a lot!
MY CONFIG:
OS: Win 10
VRam: 8Gb
Admin_KeenSWH
Previous
Return to Houdini
Users browsing this forum: No registered users and 8 guests
Fri Apr 19, 2024 1:46 am [ UTC ]
