2D surface Position noise on 3D object
Forums: 2D surface Position noise on 3D object
Houdini Integrated Plugin
Postby HBHATTI » Sat Jun 19, 2021 11:01 pm
HBHATTI Sat Jun 19, 2021 11:01 pm
I have a sphere with multiple scattered points on it, tried to use the attribnoise function applied on P, but the points are as expected transforming away from the surface; is there a way to apply 2D surface position vector without affecting the radius of the scattered points? Thanks
**I have tried using v@P = v@P - rest; ie using the rest position vector of the scattered points, but it is not giving correct results
vector rest = v@rest;
v@P = v@P - rest;
HBHATTI
Re: 2D surface Position noise on 3D object
Postby juanjgon » Mon Jun 21, 2021 9:26 am
juanjgon Mon Jun 21, 2021 9:26 am
Are you talking about the Octane native scattering feature? Can you please share your scene to take a look at it here?
juanjgon
Postby HBHATTI » Tue Jun 22, 2021 5:38 am
HBHATTI Tue Jun 22, 2021 5:38 am
Ahh sorry, I just meant the standard Houdini scattering, not octane, am attaching file; I discarded the vex attempt because I think I need a fresh start; I just need the noise to stick to the surface
2D noise.zip
(24.31 KiB) Downloaded 87 times
HBHATTI
Postby juanjgon » Tue Jun 22, 2021 9:31 pm
juanjgon Tue Jun 22, 2021 9:31 pm
You could work with the VEX noise functions, as you can see in the attached scene.
2D noise_juanjo.zip
(17.63 KiB) Downloaded 91 times
juanjgon
Postby HBHATTI » Wed Jun 23, 2021 10:58 am
HBHATTI Wed Jun 23, 2021 10:58 am
Ahh ok, thank you kind sir, appreciate it.
HBHATTI
Return to Houdini
Users browsing this forum: No registered users and 17 guests
Wed Apr 24, 2024 8:40 pm [ UTC ]
