Nested Dielectrics in production
Forums: Nested Dielectrics in production
Houdini Integrated Plugin
Postby pingovanderb » Sun Jun 13, 2021 7:24 pm
pingovanderb Sun Jun 13, 2021 7:24 pm
Long thread - big issue.
I am having challenges with Nested Dielectrics. My very real production example is the infamous beer, with bubbles, foam, and droplets on the glass. All of this is absolutely doable. The challenge comes when I wanna slap a logo on the glass and e.g. use a bump for very small droplets or condensation. I also only want the logo and condensation to only be on the outside of the glass, etc. I actually have this working now with overlap method and by assigning different texture variations to different poly groups. But this doesn't work with nested dielectrics. I know that in order for "ND" to calculate the materials need to be "single" and applied to closed surfaces. But the aforementioned beer glass material is near impossible to make into single material without UV unwrapping the whole glass and making some quite complicated map combinations or an insane node tree. So how could this be done? Suggestions:
A: I could make polygon groups and use those to color masks but as mentioned this is a super complicated workflow.
B: the ability to mix/blend materials with similar IOR without breaking the nested dielectrics. This is what works with overlap method (this works in other renders)
C: Uv sets and/or somehow using poly groups in the Octane material tree to limit texture boundaries (if this exist, I can not find it)
I'll gladly supply a test file for you to see the issue, but putting a logo on the outside of a glass with water in, should be challenging enough and present the issue.
Thanks, Pingo
pingovanderb
Return to Houdini
Fri Apr 19, 2024 12:29 am [ UTC ]
