Triplanar Texture Sliding
Forums: Triplanar Texture Sliding
Houdini Integrated Plugin
Re: Triplanar Texture Sliding
Postby DoubleTwistedCoil » Fri May 14, 2021 10:09 am
DoubleTwistedCoil Fri May 14, 2021 10:09 am
juanjgon wrote:Have you tried to add an arbitrary UV map to the object? Octane could use it as a reference in animated meshes.
I've tried and it doesn't work. What are my options? Correctlly unwrapping my geo is impossible i think. I was counting on Triplanar and now I'm in trouble.
DoubleTwistedCoil
Postby juanjgon » Sat May 15, 2021 6:21 pm
juanjgon Sat May 15, 2021 6:21 pm
Sorry, I'm afraid that there is no solution for this limitation yet. That's a common issue with all projections other than UV. Right now the only solution would be to bake the Triplanar Mapping to the UV, then use the result with a UV projection.
Triplanar projection is definitely dedicated to static or animated/non deformed meshes.
juanjgon
Postby andrevieira » Mon May 02, 2022 3:02 pm
andrevieira Mon May 02, 2022 3:02 pm
Hi guys,
Still no solution to this? It would be super useful to stick the triplanar projection result to the mesh / UVs without the need to bake!
If there's no solution, a follow up question: Is it possible to bake the texture to UDIMs?
André
andrevieira
Postby juanjgon » Mon May 02, 2022 4:04 pm
juanjgon Mon May 02, 2022 4:04 pm
Nope, not yet, sorry. The support of the "rest" attribute is planned for Octane 2022.x, so hopefully, this could help with this issue.
juanjgon
Postby jamnique » Sun Jul 24, 2022 9:07 pm
jamnique Sun Jul 24, 2022 9:07 pm
Looks like the OSL solution proposed in this thread is working:
https://render.otoy.com/forum/viewtopic.php?f=101&t=79837
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
jamnique
Postby EyasArraf » Tue Jan 24, 2023 8:46 pm
EyasArraf Tue Jan 24, 2023 8:46 pm
I agree with FakePilot on this one. While Redshift can have a Triplanar projection on deforming objects using a @rest attribute, Octane still misses this feature.
I think this feature should be suggested to Octane core devs again.
EyasArraf
Previous
Return to Houdini
Fri Apr 19, 2024 8:28 am [ UTC ]
