How to get accurate fresnel value to mix material ?
Forums: How to get accurate fresnel value to mix material ?
Houdini Integrated Plugin
Postby fantome » Wed Mar 21, 2018 9:59 am
fantome Wed Mar 21, 2018 9:59 am
Hi Guys,
I would like to understand how would you proceed in octane to blend material.
It looks that you can only mix material, so it blend in % according to the input value.
i would like to be able to use a correct fresnel function in order to do my blending.
the only one i have find is the fallof map.
the problem is that the fallof map use a strange skew factor to control the fresnel.
the behavior is describe here.
viewtopic.php?f=9&t=44730#p222947
but i would like to know how i could i use something similar base on the IOR of medium A and medium B.
basically for air to water i can enter the 2 IOR value in input and it give me the correct fresnel repartition in output.
Basically i need the octane equivalent of the fresnel VEX function.
http://www.sidefx.com/docs/houdini/vex/ ... esnel.html
Thanks for your Lights !
Cheers
E
fantome
Return to Houdini
Users browsing this forum: No registered users and 14 guests
Wed Apr 24, 2024 3:38 am [ UTC ]
