Open Live DB not opening tab
Posted:
Sun Jan 29, 2023 11:04 pm
by SpiroBunster
Hi! I am having problem opening the tab of the "Open Live DB" in Octane because it doesn't appear, it's the only tab that doesn't open, for example if I click on the "Octane Node Editor" it appears inmediately, but not with the Open LiveDB.
Somebody knows what could be, or there is another way to open that tab?
Thank you so much!
Re: Open Live DB not opening tab
Posted:
Thu Feb 02, 2023 7:03 am
by bepeg4d
ok, to share which version you are using exactly, please go to c4d menu Script/Console or Extensions/Console, (Shift+F10), and copy paste the default console output in your answer, thanks.
ciao,
Beppe
Posted:
Fri Feb 17, 2023 2:26 pm
by SWPMediaUnit
Hi! This has just started happening to me too. All was fine, but now when clicking on open live db nothing happens!
Using Cinema 4D 2023.1.3 (Build 2023.CL390584.49583)
Octane macOS 2022.1
Running on Macbook Pro M1 Max on Venture 13.2
Posted:
Tue Feb 28, 2023 7:12 am
by bepeg4d
Sorry, LiveDB is not available in OctaneX 2022.1.
It will come back with future 2023.1 version.
ciao,
Beppe
Posted:
Fri Mar 24, 2023 2:38 pm
by jaykats
Greetings,
I am running into the same issue! Do you have an estimation on when the 2023.1 version will be available?
Thank you for your time!
Kind regards,
Jay
Posted:
Fri Mar 31, 2023 9:44 am
by JamesSamson
I also want to know when 2023.1 version will be available?
Posted:
Fri Oct 20, 2023 11:51 pm
by GJs
Live DB appears not to be working in 2023.1?
All the best
Dave
Posted:
Mon Oct 23, 2023 6:39 am
by bepeg4d
Yes, 2023.1 is out:
viewtopic.php?f=85&t=82234But LiveDB is going to arrive with upcoming 2024.1 version.
For now, please have a look at this workaround:
viewtopic.php?f=7&t=75411&start=1520ciao,
Beppe
