ORC Problem. Render frames don't match (C4D)
Forums: ORC Problem. Render frames don't match (C4D)
Discussion forum for OctaneRender Cloud
Postby mguisado » Thu Jun 20, 2019 1:27 am
mguisado Thu Jun 20, 2019 1:27 am
IHello, I'm doing initial tests at OCR for rendering a +3 minute piece @1080.
The problem: I render the first frame of a sequence animation and what I get from ORC is always the same frame (which btw, it seems is a frame from outside of the range I specified)
I have to submit this tomorrow :?
Thanks in advance.
mguisado
Re: ORC Problem. Render frames don't match (C4D)
Postby bepeg4d » Fri Jun 21, 2019 6:21 am
bepeg4d Fri Jun 21, 2019 6:21 am
please load the scene in Live View, then go to menu Materials/Octane Texture Manager, and check to have not any c4d shader in your materials, you should see only ImageTexture node listed, or at least, bitmap nodes.
C4D shaders are not supposed in ORC. You need to replace them with Octane shaders, or bake them by exporting in .ocs mode.
If not enough, please save the project with assets, and share it with me, via PM.
You can share a link to dropbox or google drive, if the scene is too big.
ciao Beppe
Return to OctaneRender Cloud
Tue Feb 18, 2020 12:22 am [ UTC ]
