Are animated materials not supported on ORC?
Forums: Are animated materials not supported on ORC?
Discussion forum for OctaneRender Cloud
Postby Reality4 » Wed Jun 07, 2017 12:02 pm
Reality4 Wed Jun 07, 2017 12:02 pm
Hi, I'm trying to render animated materials on ORC.
The attached scene is an example of a box that has a Mix material that switches between a normal diffuse material and a diffuse material with emission.
Both exporting directly to ORC from 3DSMax or through Octane Standalone skips the animated materials completely.
Are animated materials not supported on ORC? Or did I miss a setting?
Unfortunately it's not possible to set the animation values inside Octane Standalone, because the animation is so complex over so many objects that it had to be scripted with Maxscript.
Thank you for any help!
emission_animation_test.zip
(117.24 KiB) Downloaded 87 times
Reality4
Re: Are animated materials not supported on ORC?
Postby Goldorak » Wed Jun 07, 2017 5:52 pm
Goldorak Wed Jun 07, 2017 5:52 pm
Odd we've rendered animated textures and materials before. If the ORBX exporter isn't catching them then this is an issue to confirm with the plugin sub form dev
Goldorak
Postby Reality4 » Thu Jun 08, 2017 11:48 am
Reality4 Thu Jun 08, 2017 11:48 am
Okay thank Goldorak. I'll just render it on my own machine now.
Reality4
Postby paride4331 » Mon Jun 12, 2017 9:34 am
paride4331 Mon Jun 12, 2017 9:34 am
Hi Reality4,
Developers report that animated material parameters issue will be fixed in 4.35;
It will be released in the next few days.
Regards,
Win 7 / i7 5930 - 32gb / 1 x quadro K620 / 2 x Evga Titan X Hybrid
paride4331
Postby Reality4 » Mon Jun 12, 2017 12:16 pm
Reality4 Mon Jun 12, 2017 12:16 pm
Thank you Paride! I got an email as well from the Otoy staff.
Great support here all around :-)
Reality4
Postby paride4331 » Fri Jun 16, 2017 7:25 am
paride4331 Fri Jun 16, 2017 7:25 am
Hi Reality4,
Octane 3dsMax plugin 4.35 is out.
Added export of animated material parameters (can be disabled in Global Settings).
viewtopic.php?f=80&t=61817
paride4331
Postby Reality4 » Fri Jun 16, 2017 9:05 am
Reality4 Fri Jun 16, 2017 9:05 am
Great, thanks!
Reality4
Return to OctaneRender Cloud
Mon May 21, 2018 3:25 am [ UTC ]
