Multishader on Asset "Magazine" Preset
Forums: Multishader on Asset "Magazine" Preset
Moderator: aoktar
Postby Omski » Mon Apr 22, 2024 6:03 pm
Omski Mon Apr 22, 2024 6:03 pm
I'm using the Magazine Preset from the C4D library. It uses 2 materials to distribute the pages to the magazine, both materials driven with the Mograph Multishader. It works totally fine in the viewport and with the Standard renderer. However, when I switch to the Octane Live viewer, it only displays the first texture from the Multishader materials.
Nice:
Nono:
Attached are two files: one for Standard renderer and one with Octane Materials:
"Check Magazine_oct_2" (working fine in C4D)
"Check Magazine_oct_4.c4d" (not working with Octane Materials)
I couldn't figure it out, so with a bit of luck, someone here can help.
Cheers
C4D 2024.3.2.
Octane 2023.1 (R2)
Check Magazine_oct_4.c4d.zip
(13.35 MiB) Downloaded 26 times
Check Magazine_oct_2.zip
(13.15 MiB) Downloaded 23 times
Omski
Re: Multishader on Asset "Magazine" Preset
Postby bepeg4d » Tue Apr 23, 2024 7:23 am
bepeg4d Tue Apr 23, 2024 7:23 am
you need to use an Instance Range node with the Maximum value equals to the number of pages you have, then connect it to an Octane Gradient node in Complex mode, and create as many gradient knots as the number of pages, finally connect the desired textures to the knots pins:
ciao,
Beppe
Postby Omski » Tue Apr 23, 2024 9:20 am
Omski Tue Apr 23, 2024 9:20 am
Thanks for the quick response, Beppe!
I'm trying to rebuild your setupnow.
Works fine for the Pages 1-3 but then on Pages 4-end i get a wild mix....
Could you pleas have an eye on the C4D dokument? What am i doing Wrong?
C4D attached
#UPDATE!!
Got it!
7 pages and only value 6 on the Instance Range Nodes!
Then wild sorting.
BIG THANK YOU!
Check Magazine_oct_6.c4d.zip
(16.11 MiB) Downloaded 16 times
Omski
Return to Maxon Cinema 4D
Users browsing this forum: Bing [Bot] and 5 guests
Tue Jun 04, 2024 12:18 pm [ UTC ]
