Motion blur doesn't work with Camera morpher in C4D
Forums: Motion blur doesn't work with Camera morpher in C4D
Postby lakistrike » Tue Jan 28, 2020 11:44 am
lakistrike Tue Jan 28, 2020 11:44 am
Any idea why motion blur is not working when using camera morpher in c4d? I have 2 cameras, both have camera tags on them, both have turned on motion blur. Also the camera with a morpher camera tag has all of these turned on. The DOF works but motion blur doesn't.
lakistrike
Re: Motion blur doesn't work with Camera morpher in C4D
Postby aoktar » Tue Jan 28, 2020 11:09 pm
aoktar Tue Jan 28, 2020 11:09 pm
It will use the camera tag parameters from the active camera, not will evaluate what you do with camera morpher.
Postby lakistrike » Fri Jan 31, 2020 5:17 pm
lakistrike Fri Jan 31, 2020 5:17 pm
But they do have all parameters turned on. All camera tags have them.
Here's the setup:
lakistrike
Postby frankmci » Tue Feb 04, 2020 4:40 pm
frankmci Tue Feb 04, 2020 4:40 pm
Which versions are you using? It seems to be working fine in 2019.1.5 with C4D R21. I just put the Octane Camera tag on the Morph Cam itself. It seems to do both camera motion blur and object motion blur. We don't do much vertex level motion blur, though, so I haven't tested that recently.
C4D Camera Morph Motion Blur - spheres are camera blur, green cube is transform blur
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby Climax.exe » Thu Aug 17, 2023 10:54 am
Climax.exe Thu Aug 17, 2023 10:54 am
Hi guys, i just found the answer.
All you have to do is putting all your morphed cams in a group ;)
Climax.exe
Postby ervinhaley » Mon Aug 21, 2023 2:25 am
ervinhaley Mon Aug 21, 2023 2:25 am
Motion blur is not supported with the Camera Morpher. The Camera Morpher modifies camera properties like focal length, position, rotation etc over time. This type of animation may not be compatible with Cinema 4D's motion blur features. The motion blur settings may be ignored when using the morpher. drift hunters
ervinhaley
Wed May 08, 2024 8:32 am [ UTC ]
