EK waterblock but bear mind that you need 3-4 exactly the same gpus to watercool them at once.
http://www.amazon.com/EVGA-GeForce-384- ... tx+780+6gb
2x D5 PWM pumps with tops
1x reservoir
2x480 radiators
20 120mm fans
fittings
tubing
temp sensor
controller
waterblocks and backplates
glimpse wrote:safe anough, but get better fans if noise isn't a problem, tune a lot of airflow through Your case. if that is not going to help, manually set lower temperature target & it should be fine =) but You start loosing render performance. Watercooling is another option..
Users browsing this forum: No registered users and 24 guests
