1. Octane (demo 2.06) works on 970/980
2. These scores are thanks to overclock.net users whom I asked to run the demo scene
http://render.otoy.com/forum/viewtopic. ... +your+rigs
The thread is available at
http://www.overclock.net/t/1514149/octa ... lease-help
RESULTS - pathtracing, alphashadows off
970: 3.43M/sec (1430mhz core/8224mhz memory)
Hope to get more results soon.
PS.970 performs almost the same as 670 and same as 580 and look at this overclocked clocks!
Price is relatively low 330$ but I expected something more.
What do you think?
EDIT from GoldenTiger (overclock.net)
EDIT:
Direct lighting mode, same speeds/etc. as above alpha shadows disabled...
SCORE/rendering speed: 22.4M/sec
POWER: 70.0% tdp
PMC mode, same speeds/etc. as above...
Gives an error saying (failed).
Going to guess something is wrong with the driver compatibility frown.gif as it is downclocking my memory and the PMC mode is failing outright?
EDIT 2: Power figures edited in (and I had the wrong number for direct lighting, forgot to disable alpha shadows before). PMC mode says "failed" but has no speed figure. At everything default speeds in afterburner (1315mhz boost) it also fails (no speed readout, just shows what it did before changing modes from direct lighting at any given point).
Edited by GoldenTiger - Today at 2:13 am
