What render mode are you using?cfrank78 wrote:I get about 1.93 with my gtx 560TI and about 2.27 with my gtx 660 TI MSI.
I get similar results as you with path tracing.
When using PT my gtx 560 scores 1.63.
Suv
I used Pathtracing with the optiones i should use, told in the first post. Alphashadows disabled and so on. But i thing the guys in the other threads used pathtracing too right?What render mode are you using?
Suv
Refracty you tell me 2.58 was faster than the final release? did i understand you right? Why is this? Thats strange!maybe they used an older version 2.58 wich was faster
Hi Refracty!Hi Chris,
to embed instancing functionality the new releases are a little bit slower then 2.58 release.
So there is a difference of speed results depending on what release was used for the benchmark.
Thank you very much - i think i will get the 680. I think that Kepler will be faster in the future - when new updates will come. Fermi is hard to get and new customers wanna have speed too4 * 580s 3GB or 4 * 680 4GB are both good choices. If you don't want to water cool (what will raise the costs) I would go with the 680s. They consume less energy and doesn't heat up so quick.
580s are 10 % faster but the 680s will give you a bit more textures and VRam.
So If I would choose a system today I would go with 4 * 680s in an air cooled case.
glimpse wrote:Are You sure? =) Any printscreen to base Your performance claim?..igen wrote:I forgot the detail .... 2 zotac gtx 690 ~ 44Ms/sec use pathtracing
