I will be great to be able to use animated image map into standalone.
I mean a RBG or Float image node who can load a image sequence synchronized  with scene actual frame.
They're multiple scenario where it can be very usefull :
in a lighting context (be able to make animated lighting)
*timelapse environnement
*flashing or animated lighting stuff
In a texturing/blendind context :
*for a character who use differents textures according to different blendshape.
*"age" texturing : think to tree season for example.
*Dirt or cleaning effect : a car car who'getting dirty for example.
*Making surface effects : making rain drops rolling on surface.
In camera mapping context :
no need to explain here.
In motion graphics  context :
just be able to use animated motion graphics as texture
I could continue this list forever. I'm using this almost in all project i'm working on and it's a real problem to me to not be able to do this in Octane.
						Which feature do you need the most?
- blobbybarack
- Contact:
- Rikk The Gaijin
You can already do this by using mix material nodes and Lua script.blobbybarack wrote: *for a character who use differents textures according to different blendshape.
- blobbybarack
- Contact:
I get your point Rikk The Gaijin.Rikk The Gaijin wrote:You can already do this by using mix material nodes and Lua script.blobbybarack wrote: *for a character who use differents textures according to different blendshape.
But when i read "you can already do this" i read : "you could dev it by yourself".
To my knowledge there is not such a script right now but i could be wrong.
My script and LUA scripting is pretty low for now and it looks like an impossible task to me right now.
I do not have a dev profile.
I'm only able to do light modification on existing scripts for now.
I don't want to be rude or something but i'm pretty confuse about animation integration into Octane Standalone.
Yes, i'm really happy since Alembic features came in (with animation script) but it's not enough to me.
I'm just seeing those tools as a temporary solution to the lack of functionality related to animation into standalone.
From what i understood almost every scripts related to animation are coming from the community and i'm really thankful for that.
I'm really curious about the Otoy road map about animation into standalone :
*let the community do the job through LUA scripting ? (again thanks for this powerfull tools even if i can't use it right now)
*Otoy is working hard on some new animation related script who will be cheap with future version ?
*Integrate more deeply animation into the software as a core feature ?
I don't talk about making animation/keyframing job into Octane of course but working on a more solid and reliable animation workflow.
I know this is stupid to compare one render engine with others. Even more when we talk about Octane. But things like image sequence as textures or animation batch rendering are trivial in any render engine i've already use.
Again, i don't want to be an hater/complaining guy, i know, this a relatively new technology and the Otoy team made a incredible job recently on pure rendering features (displacement at this speed : OH MY..").
But to me it's a mistake to forgot this kind of stuffs.
As an example, talking about cloud rendering before to be able to do batch rendering in a complete non sence to me.
EDIT :
Users who are going through plugin have already this feature available, please add this to standalone.
http://render.otoy.com/forum/viewtopic. ... 28#p195614
- Rikk The Gaijin
There is, as I requested it a while ago.blobbybarack wrote:To my knowledge there is not such a script right now but i could be wrong.
 http://render.otoy.com/forum/viewtopic. ... 28#p166428
- Vue2Octane
I would like a
RENDERLOCK
which disables the automatic update once I started a render.
It happens quite often to me, that I start a final render that takes like 2h or longer and in between I accidently double click on sth. like the render window when I use a mouse pad. This would change the point of view and the entire render automatically starts over.
It is nice for previewing, but once I final render, it would be great if the render can only be changed/stopped when I explicitely press the pause or stop button.
						RENDERLOCK
- Seekerfinder
Yes please!Vue2Octane wrote:I would like a
RENDERLOCK
Win 8(64) | P9X79-E WS  |  i7-3930K  | 32GB  |  GTX Titan & GTX 780Ti | SketchUP | Revit | Beta tester for Revit & Sketchup plugins for Octane
						- blobbybarack
- Contact:
Thanks it could be usefull even if it's not what i'm looking for.Rikk The Gaijin wrote:There is, as I requested it a while ago.blobbybarack wrote:To my knowledge there is not such a script right now but i could be wrong.
Any news on the possibility to outsource some of the textures to the system ram?
							Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
						At the rate we are asking for new features and the demand for more speed + better plugin integration, octane dev team should be double or triple it's size.
I think about 25-40% of what we ask for will be done in 2.X.
