Lut's
Forums: Lut's
Area for student license holders to post questions and discuss octane.
Lut's
Postby merid888 » Wed Oct 04, 2023 12:32 am
merid888 Wed Oct 04, 2023 12:32 am
Does any one have Lut's to exteriors ?
I mnean, free Lut's dosen't have realistic finish in the picture like movies
W11 x64 Bits Workstation, 32 Gb 3200 Mghz DDR4 Corsair, Asus X570 Plus Wifi, Ryzen 9 5950x 3.4 Ghz, M2 WD Black-SN850x 1 Tb, Corsair H100i RGB PLATINUM, 1 RTX A4000 16 GB, 1 Power Supply Corsair RM850x.
merid888
Re: Lut's
Postby elsksa » Wed Oct 04, 2023 2:59 pm
elsksa Wed Oct 04, 2023 2:59 pm
It takes a lot more than just a mere 3D LUT, on movies.
For instance, there's what’s called a “show LUT”, which is used as a rough look on-set, but in post it’s a whole different story. LUTs have been over rated and misunderstood for a while. The blatant misinformation online contributed to it.
First and foremost, the LUT has to be compatible (format and color space specifications). Since they’re primarily created for digital cameras, most won’t fit for Octane.
They won’t be enough for a proper rendition either. Here’s some reading about it.
Here’s a much superior solution to LUT. It doesn’t come with different looks but that’s possible, either via OCIO or in post such as in a compositing software (literally takes seconds to set it up).
It’s overwhelming, but worth it at the end and most importantly, an absolute necessity. Understanding the fundamentals of how an image is formed and pixels are managed allow for more technical and creative control.
elsksa
Re: Lut's
Postby merid888 » Thu Oct 05, 2023 5:56 pm
merid888 Thu Oct 05, 2023 5:56 pm
Thank you for response me elsksa, I'll read you suggestion to undestand more about Luts
Very kind elsksa
merid888
Re: Lut's
Postby merid888 » Thu Oct 05, 2023 7:19 pm
merid888 Thu Oct 05, 2023 7:19 pm
Hello elsksa, here again bothreing you, I been readed the post and I been followed the steps, nothing happen, is the same picture like before.
Add screen shot.
Hope you can help me with a tutorial or guide or some useful.
Thank you so much elsksa.
Test AgX
AgX
merid888
Re: Lut's
Postby elsksa » Fri Oct 13, 2023 2:38 pm
elsksa Fri Oct 13, 2023 2:38 pm
It seems AgX hasn't been properly loaded (the .ocio file). Could you show this as well? I assume it's in the preferences.
OCIO is explained here.
elsksa
Re: Lut's
Postby elsksa » Fri Oct 13, 2023 2:56 pm
elsksa Fri Oct 13, 2023 2:56 pm
By the way, you might be interested in this. Since you were referring to "movie looks", here's a recent publication that will give you the possibility to achieve so. Mostly in post, unless you have OCIO "skills" to bake it to an OCIO config-file (that's possible).
elsksa
Return to General Discussion
Sun May 26, 2024 12:23 am [ UTC ]
