Octane Scatter and instances
Forums: Octane Scatter and instances
Area for student license holders to post questions and discuss octane.
Postby kikicobos » Fri Feb 07, 2020 3:08 am
kikicobos Fri Feb 07, 2020 3:08 am
Hello, I was following this tutorial: https://youtu.be/etSTx4SJ6j4
I got stuck early on using instances with octane scatter . When I tried to move/copy/rotate the instance, the trees (forester) don't stick. Can someone guide me or point to a helpful tutorial about how to make the trees stick. I appreciate it!
kikicobos
Re: Octane Scatter and instances
Postby frankmci » Fri Feb 07, 2020 4:27 pm
frankmci Fri Feb 07, 2020 4:27 pm
It seems to be working fine, as demoed in the tutorial. I suggest you try it again, with very simple objects, to get a feel for the relationships. Try something like this:
Simple Scatter Tree Mountains
What you are describing is usually caused by accidentally transforming multiple levels of a hierarchy at once, instead of just manipulating the top level and letting the child object automatically inherit the transform. Be careful of exactly what you have selected when moving and rotating your instances.
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby kikicobos » Sat Feb 08, 2020 9:28 pm
kikicobos Sat Feb 08, 2020 9:28 pm
Thank you for the reply, I will check it out
kikicobos
Postby Viltae » Wed May 20, 2020 1:43 pm
Viltae Wed May 20, 2020 1:43 pm
Hi!
Back to Octane (not used for years) and I wanted to follow this tutorial too but on Max. Everything works but I couldn't find Octane Scatter. Is it C4D specific?
Viltae
Postby SSmolak » Wed May 20, 2020 2:29 pm
SSmolak Wed May 20, 2020 2:29 pm
Viltae wrote:Hi!
As I know - Yes. Some time ago Ahmet said that maybe there will be standalone plugin for scattering.
SSmolak
Postby Viltae » Wed May 20, 2020 9:05 pm
Viltae Wed May 20, 2020 9:05 pm
Oh, how sad! An Octane specific solution would have been welcome! Thank you for your reply.
Viltae
Return to General Discussion
Tue Jun 04, 2024 8:11 am [ UTC ]
