OctaneRender 2020 for AutoCAD [OBSOLETE]
Forums: OctaneRender 2020 for AutoCAD [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
Postby face_off » Wed May 06, 2020 3:08 am
face_off Wed May 06, 2020 3:08 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for AutoCAD TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date. If in doubt, run Octane Standalone, then add and click on a Rendertarget to make sure it starts rendering.
2) If the Octane Camera direction does not match up with the AutoCAD camera, Rightclick the XYZ axis in the AutoCAD viewport and select "World".
3) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin
AutoCAD Version
The plugin requires AutoCAD 2019 Windows 64bit.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- AutoCAD version and build number
- OctaneRender for AutoCAD version (ie. 1.20.1.10)
For more information...
- Specific Octane 2.0 features in this plugin http://render.otoy.com/manuals/AutoCAD/?page_id=661
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Download Links
Current STABLE build (Octane 2020.1)
Release Notes
2020.1.0.29 (06-May-2020)
- Compiled with Octane 2020.1
- Added Kosek-Wilke Daylight Model
- Added the Hair Material node
- Added the Random Walk medium
Return to Autodesk AutoCAD
Tue Jun 04, 2024 10:49 am [ UTC ]
