softimage baking id problem
Forums: softimage baking id problem
Postby Matteo3d » Wed Jul 13, 2022 1:13 pm
Matteo3d Wed Jul 13, 2022 1:13 pm
hi boys,
I would like to create a baking of a model,
I created various uvs with projections and materials,
now, I created a second uv "for baking in octane, but, when I'm in octane (standalone) I insert uv set (second uv) but, nothing happens, render black !,
does anyone know how to set this up?
thank you
win 10, 64 gb, 2x 1080ti
Matteo3d
Re: softimage baking id problem
Postby jobigoud » Wed Jul 13, 2022 7:15 pm
jobigoud Wed Jul 13, 2022 7:15 pm
This kind of question should go in the General Discussion forum.
Baking with alternate UVs should work, here I made a test scene with a geometry with 2 UV sets and the baking camera can bake based on either one.
baking-uvsets.orbx
(180.69 KiB) Downloaded 253 times
The right UV set should be selected in both the baking camera and the texture projection.
If your object has an object layer map associated with it, check that the object layer Baking group ID matches the one from the baking camera.
jobigoud
Postby Matteo3d » Sat Jul 16, 2022 8:32 am
Matteo3d Sat Jul 16, 2022 8:32 am
thank you very much for your support,
in softimage, I create a geometry, apply different materials, two uvs, 1 with texture mapping, 2 for baking,
in your example I see only one material, I cannot manage the different materials of my geometry
Matteo3d
Postby jobigoud » Sat Jul 16, 2022 11:12 am
jobigoud Sat Jul 16, 2022 11:12 am
Having several materials shouldn't be a problem. But I don't know Softimage maybe something is lost between the exporter and Octane's importer. Can you create a simplified geometry and attach it here so we can test? Thanks.
jobigoud
Postby Matteo3d » Sun Jul 17, 2022 6:56 am
Matteo3d Sun Jul 17, 2022 6:56 am
Certainly!
here is the file,
https://fromsmash.com/cGi0h-7Hpt-dt
a simple cube, with 6 materials
Matteo3d
Return to Works In Progress
Users browsing this forum: No registered users and 5 guests
Mon May 20, 2024 12:50 pm [ UTC ]
