remember kernel settings when switching between kernels
Forums: remember kernel settings when switching between kernels
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby Dingbat » Fri Aug 04, 2023 10:05 am
Dingbat Fri Aug 04, 2023 10:05 am
i often switch between Direct Light and Photon Tracing kernels (mainly for pool caustics) and it would be really handy if the settings could be remembered as every time i need to switch i need to manually set myself
Dingbat
Re: remember kernel settings when switching between kernels
Postby Daniel_Ward » Wed Aug 09, 2023 9:38 pm
Daniel_Ward Wed Aug 09, 2023 9:38 pm
I find the saving Render Target to View to be very temperamental with the AC plugin. I always save a set of Render Target settings files for each view and apply/resave them every time I make changes and or change between Render Targets.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Daniel_Ward
Postby face_off » Wed Aug 09, 2023 10:41 pm
face_off Wed Aug 09, 2023 10:41 pm
I would have thought this would happen automatically. I will check on this the next time I am working on the plugin.
Postby face_off » Thu Aug 17, 2023 9:06 am
face_off Thu Aug 17, 2023 9:06 am
I just checked this, and changing the kernel type was remembering the common pin values. Are you able to provide more details on how this is not working for you please?
Return to Graphisoft ArchiCAD
Fri May 24, 2024 7:12 pm [ UTC ]
