How to add a color correct node?
Forums: How to add a color correct node?
Postby Dingbat » Wed Apr 21, 2021 7:27 pm
Dingbat Wed Apr 21, 2021 7:27 pm
hopefully missing something obvious but can't seem to find a way to do this?
is it possible to do a simple CC (a hue correction) to a diffuse map?
Dingbat
Re: How to add a color correct node?
Postby Daniel_Ward » Wed Apr 21, 2021 8:38 pm
Daniel_Ward Wed Apr 21, 2021 8:38 pm
Hey Dingbat,
make the Diffuse node a "Colour Correction Node", then put your diffuse map into the input node.
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Daniel_Ward
Postby Dingbat » Thu Apr 22, 2021 10:51 am
Dingbat Thu Apr 22, 2021 10:51 am
thank you. that works but unfortunately it's not at all user friendly.
size from AC material is not carried over so it takes way too long to set up (texture size, origin etc).
ideally need a way to simply CC an already existing material without changing existing parameters.
Dingbat
Postby Daniel_Ward » Thu Apr 22, 2021 7:45 pm
Daniel_Ward Thu Apr 22, 2021 7:45 pm
Hi Dingbat,
my workflow is to first "copy" the diffuse node, then change it to a CC node, then select the input channel and "paste", which then automatically picks up all of the original diffuse channel settings from ArchiCAD. It's pretty seamless.
Cheers, Dan.
Daniel_Ward
Postby Dingbat » Fri Jun 04, 2021 4:31 pm
Dingbat Fri Jun 04, 2021 4:31 pm
Thanks Dan, that works well /thumbsup/
Dingbat
Return to Graphisoft ArchiCAD
Who is online
Mon May 20, 2024 2:55 am [ UTC ]
