OctaneRender for DAZ Studio 2022.1.1 - 303 [OBSOLETE]
Forums: OctaneRender for DAZ Studio 2022.1.1 - 303 [OBSOLETE]
Moderator: BK
Postby toby_a » Mon Apr 17, 2023 12:04 am
toby_a Mon Apr 17, 2023 12:04 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for DAZ Studio - TEST (ie. pre-release) releases.
TEST releases contain new features or substantial changes that, while expected to work, have not yet been proven stable.
PLEASE do NOT use them for important work and DO report any issues or suggestions as a reply to this post.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you are running the latest version of the OctaneRender for DAZStudio plugin.
3) If you experience a DAZStudio crash - deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb may resolve the issue.
This also resolves the "COULD NOT INITIALISE IN-MEMORY DB!" error on startup and a number of other issues.
4) If the Save button is disabled when using the Final button - disable the Final button and in Render settings select the SuperScope (2:1) Size / aspect ratio and drag the Viewport height or width until you reach required resolution.
5) If rendering an animation fails after 11 frames - make sure the DAZStudio viewport is visible when you render the animation.
6) If Octane materials are not loading when you load a previously saved scene - tick Preferences->Load OctaneRender materials from .duf user presets. If ticking this option does not stick between DAZStudio restarts, delete OctaneRender_settings.oczdb as per NOTE 3 above.
7) If you get a "Could not save a frame for X times!" - please search the forum for potential solutions.
8) If you get a "Bogus Scene Path" error - this is due to having an apostrophe in the filepath of a texturemap (so store your textures in foldernames which do not have apostrophes).
9) Octane panel title bar is off the screen and cannot be closed - click anywhere on the Octane panel and then press Alt-F4.
10) Rendering animation results in the scene emitter intensities changing - this is because rendering animations is done in "Final" mode, where meshes are merged. To resolve this, UNTICK the Preferences->Use Combined Mesh, or ENABLE the Surface Brightness pin on each of the emission materials in the scene.
11) Denoiser is not working - make sure you have a graphics card selected for Denoising in the System tab->Open Device Settings window, and that you are using the Path Tracing kernel.
12) Render artifacts near eyebrows - this is due to the eyebrow geometry going inside the head mesh surface. So morph, move or scale the eyebrows so they do not intersect with the head mesh.
13) Octane panes do not appear on the screen (ie. they open off the screen) - Main Menu Bar->Window->Workspace->Select Layout->Accept (you might choose a different layout to the current layout to make this work).
KNOWN ISSUES AWAITING RESOLUTION
1) Panoramic camera and OSL nodes are not currently supported.
2) Templating is not currently working for specular and roughness maps from Iray materials. - FIXED (please report any issues)
3) UDIM Tiles are not currently supported. - FIXED (please report any issues)
4) Some of the newer OctaneRender material and texture types are not supported. - FIXED (please report any issues)
5) VDB volume and volumetric spotlight nodes are not currently supported.
DAZ Studio Version
DAZ Studio 4.8 or later on Windows 8, 10 or 11 64bit
To use this version, you need a GPU of compute model 3.5 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped.
Also, make sure you use an Nvidia Studio driver of version 456.38 or higher.
Network Rendering
For Network Rendering, you must use the OctaneRender Studio+ Node release from the Octane Standalone forums/download page which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Studio+ 2022.1.1 Render Node builds.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win 8, 10, 11)
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- DAZ Studio version
- OctaneRender for DAZ Studio version (e.g. 2022.1.1_303) and subscription type (Studio+/Prime)
- The most important part of resolving a problem is being able to reproduce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Changes since 2022.1.1 - 302
  • Fixed a regression that caused the context menu in the node graph editor to not work
  • Added the ability to use the Panoramic camera
    There is a new property "Camera Type" on DAZ camera nodes that can be changed from the default of "Thin-lens camera" to "Panoramic camera".
Changes since 2022.1.1 - 301
  • Fixed some issues with saving and loading scenes containing duplicated nodes
  • Fixed a crash caused by deleting an Octane material from the DAZ Studio Scene tab
  • Fixed a case where changes in the scene were not picked up following clearing the scene using File->New
Changes since 2022.1.1 - 212
  • Redesigned material node value animation
    This version includes a complete redesign of the way material properties can be animated. In previous versions, there was a way to define animations for material nodes in the node editor, but this did not work properly and has been removed.
    Please see the announcement post for version 2022.1.1_301 (viewtopic.php?f=44&t=81456) for details.
Download Links
Please feel free to report any issues you encounter.
Happy rendering
Your OTOY team
toby_a
Re: OctaneRender for DAZ Studio 2022.1.1 - 303 [TEST]
Postby alaman64 » Mon Apr 17, 2023 3:30 pm
alaman64 Mon Apr 17, 2023 3:30 pm
Hi Toby,
Just did a quick test of the panoramic camera and it works as expected. Thanks so much for this, I've been waiting years for this change. I will do some more testing today and tomorrow, but so far looks good.
Thanks again! :D
Asus Z97-A / usb 3.1 - Windows 10 - 980 ti - Titan Black - Titan Z - Daz Studio
alaman64
Postby alaman64 » Mon Apr 17, 2023 3:42 pm
alaman64 Mon Apr 17, 2023 3:42 pm
Just a small bug, when you select panoramic camera, change stereo output type to "side by side", and then change field of view. Works good, but when you save and re-load, the parameters that were changed are lost. Not a big deal for me, but could be annoying to some.
alaman64
Postby toby_a » Mon Apr 17, 2023 9:34 pm
toby_a Mon Apr 17, 2023 9:34 pm
alaman64 wrote:Just a small bug, when you select panoramic camera, change stereo output type to "side by side", and then change field of view. Works good, but when you save and re-load, the parameters that were changed are lost. Not a big deal for me, but could be annoying to some.
Thanks for testing! I'll look into what's going on here.
toby_a
Postby toby_a » Wed Apr 19, 2023 12:30 am
toby_a Wed Apr 19, 2023 12:30 am
This is a bug that will be fixed in the next release.
toby_a
Re: OctaneRender for DAZ Studio 2022.1.1 - 303 [OBSOLETE]
Postby toby_a » Wed Apr 19, 2023 1:45 am
toby_a Wed Apr 19, 2023 1:45 am
A new TEST version has been released: viewtopic.php?f=44&t=81523
toby_a
Return to DAZ Studio
Who is online
Users browsing this forum: No registered users and 2 guests
Thu May 23, 2024 3:36 am [ UTC ]
