I also have 2 GPU's and did quite some research before installing them.birdovous wrote:Finally got to installing the DAZ 4.8 and the OcDS v2.2.
All seems to work relatively well except for one odd message that just keeps popping up in the System/Messages part of the plugin while rendering (screenshot attached). I have never seen this message in past. Truth is, that in past I was using a GTX Titan and a GTX 780 Ti while now I replaced them by two GTX Titan X cards. Nvidia driver version is 353.06.
I tried to google the message and search the forums in here but I did not find any clues.
Any ideas?
I think this means that your cards are getting too hot. When this happens, they automatically clock down to prevent damage.
To have them operating at their full clock speed you'll have to provide better ventilation.
Mostly you can get away with running the GPU's ventilators at higher speed, some software to adjust the default speed should be included with your cards (eg. MSI has Afterburner).
On most cards, initial ventilation speed is quite low to prevent noise.
Peter.
