AI Upscaler makes things look worse ... why?
Forums: AI Upscaler makes things look worse ... why?
Moderator: BK
Postby SparkieShock » Thu Sep 21, 2023 4:44 am
SparkieShock Thu Sep 21, 2023 4:44 am
Okay .. I admit defeat. After trying the upscaler I have found that all it seems to do it to downscale things?
Clearly I'm using it wrong .. but I fail to see how. Once enabling the upscaler .. and selectring 2x2 or 4x4 you'd think it would turn a 1080 image into a 2160 .. or something along those lines. Instead the opposite is happening where the image is becoming less in resolution.
Any suggestions?
First image .. upscaler is OFF
Second image .. upscaler on 4x4
.....WTF?
Win 10 Pro Edition - Intel i0 10900X - X299 MB - 128GB's KINGSTON FURY 3200 RAM - 2x RTX A6000 GPU's - 1300 Watt Power
DAZ3D - BLENDER - OCTANE STANDALONE and PLUGIN FOR DAZ - OCTANE PRIME for DAZ
SparkieShock
Re: AI Upscaler makes things look worse ... why?
Postby ricky_otoy » Thu Sep 21, 2023 6:46 am
ricky_otoy Thu Sep 21, 2023 6:46 am
What you are seeing is when you use 4x4, octane renders the image 4x smaller and upscales back to your current resolution. Turning on AI upsampling should help.
ricky_otoy
Postby SparkieShock » Thu Sep 21, 2023 8:08 am
SparkieShock Thu Sep 21, 2023 8:08 am
But I do have it on ... and everything looks worse.
The button for 'Enable AI upsampling' is ON.
There's nothing else to select, so I don't understand what to do about this. Except to not use it because it is reducing resolution.
SparkieShock
Postby ricky_otoy » Thu Sep 21, 2023 8:35 am
ricky_otoy Thu Sep 21, 2023 8:35 am
Try setting your resolution to the scale you want your output to be. (ie. 4000x4000) Then use the upsampler at 4x4. This will effectively render the scene at 1000x1000 and upsample back to 4000x4000.
I think it works better on larger images if I am not mistaken. That being said, I would rather set your required higher output resolution with lower samples and then use the denoiser.
ricky_otoy
Return to DAZ Studio
Tue Jun 04, 2024 11:48 am [ UTC ]
