OctaneRender 2023 for Rhino (TEST and STABLE)
Forums: OctaneRender 2023 for Rhino (TEST and STABLE)
Postby face_off » Wed Oct 18, 2023 12:33 am
face_off Wed Oct 18, 2023 12:33 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Rhino - TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you have the latest Rhino Service Release installed.
3) If you get an "Error Starting Octane - Could not load OctaneWrapper?.dll" error when installing the plugin, this is generally due to not having the latest NVIDIA drivers installed (so see Solution 1) above.
4) If you get a "Package not compatible" error when installing the plugin, please follow the instructions at https://wiki.mcneel.com/rhino/5/rhi-problems -> "Package not compatible".
5) If you get an "Unable to load OctaneRenderForRhino.rhp plugin: initialization failed" error when starting the plugin, delete the HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0\Plug-Ins\F109BD23-4CF3-4C0B-9F83-06BE474B0152 and HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\Plug-Ins\F109BD23-4CF3-4C0B-9F83-06BE474B0152 registry entries using Regedit and then reinstall the plugin. If this does not resolve the problem, delete HKEY_CURRENT_USER\Software\McNeel\Rhinoceros from the registry and then reinstall the plugin.
6) If you get an "OctaneRender for Rhino not activated." error when rendering via the Rhino->Render->Render menu, open the plugin Setup window via the OctaneRenderForRhino command, or by adding the plugin panel to the Rhino Properties window as per https://docs.otoy.com/RhinoH/RhinoPluginManual.htm#Rhinoceros/InstallationofthePluginintoRhinoceros.htm.
7) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin
8) The Octane Viewport does not appear after clicking the Open Viewport button. This occurs when the Viewport was previous closed on a second monitor, or off the current screen. To resolve this, delete the plugin configuration file config.xml as per https://docs.otoy.com/RhinoH/RhinoPluginManual.htm#Rhinoceros/Configuration.htm.
9) LiveDb materials containing OSL nodes will not load into the plugin correctly. The plugin does not currently support OSL Projection or Texture nodes. Instead, copy these Livedb materials into the clipboard from Octane Standalone and paste them into a NodeGraph material in the plugin.
10) Where is the macOS version? I have done quite a lot of work investigating a macOS version of the plugin for Rhino. Unfortunately the macOS UI that Rhino uses offers far fewer controls than the Windows version, and I don't think it's possible to replicate the tree structure that the plugin uses in Windows. So I think it would require a complete re-write of the plugin in order for it to work on macOS, and I don't think that would be possible in the near future.
11) If when rendering with Octane 2021, the render appears to be using a different color map, set the Kernel->White Light Spectrum to Legacy/Flat to render as per Octane 2020.
12) Rhino locks-up/freezes when loading a .3dm containing Octane data. This is due to the plugin searching through very large (or invalid) folders searching for missing texturemaps. To resolve this, delete the plugin configuration file config.xml as per https://docs.otoy.com/RhinoH/RhinoPluginManual.htm#Rhinoceros/Configuration.htm.
Rhino Version
This version requires the latest Rhino 6, 7 or 8 build, on Windows. MacOSX is not currently supported.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 451 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Rhino version and build number
- OctaneRender for Rhino version (ie. 2.0.10.8)
For more information
- Watch Iceglance's quickstart tutorial http://render.otoy.com/forum/viewtopic.php?f=51&t=36299
- Read the on-line manual
- Watch the "Getting Started" video http://vimeo.com/73202740
- NodeGraph material tutorial - https://youtu.be/Yd7jkAnRZpg
- Shadow Passes tutorial - https://youtu.be/ozW98ZjeXYM
- Exporting from Bongo to Octane Standalone - https://vimeo.com/116603709
- Camera Motion Blur in OctaneRender for Rhino - https://vimeo.com/90721378
- Rhino HDRLS integration with OctaneRender - https://vimeo.com/104381431
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Known Issues
- Prior to rendering a Sun Study, Flythru Animation or Bongo Animation, you must select the Perspective Viewport in Rhino that the animation uses
Download Links
NOTE: Rhino files saved with this version of the plugin may not open with the Octane 2022 or previous versions of the plugin.
Current STABLE build (Octane 2023.1.2)
Previous TEST build (Octane 2023.1)
Release Notes
2023.1.2.138 (4-Mar-2024)
- Compiled with Octane 2023.1.2
- Added support for WscBox mapping from Rhino materials to the Octane Viewport, and from Octane materials to the Rhino Viewport. The later requires Rhino8 SR3.
2023.1.0.137 (18-Oct-2023)
- Added all new Octane 2023.1 Output AOV, Textures and Texture Layer nodes
- The Compositor pin on the Rendertager is now the Output AOV pin
- Added Iridescent node (which was previously missing)
- The Composite nodes from Octane 2022.1 are now in the Output AOV pin of the Rendertarget
- Added all Texture Layer nodes from Octane 2023.1
- Added the Interpolation Color Space pin to the Volume Gradient, Gradient Map and Toon Ramp nodes
- Added Dispersion Mode to the Standard Surface Material, Specular Material, Specular Material Layer, Universal Material. This defaults to "Abbe number". Change this to "Cauchy formula" in order to render as per Octane 2022.1
- Added Cast Photons to the Environment
- Added the Enabled pin for each material input of the Composite Material
- Added save formats TIF and JPEG
- Not implemented yet
    *Switch nodes
    * Analytic and Directional lights
    * Offset the time in an animation from an ORBX proxy
    * Output AOV->Apply Custom Curve
    * Directional Light
    * Custom LUT
Re: OctaneRender 2023 for Rhino (TEST and STABLE)
Postby Refracty » Wed Nov 29, 2023 2:49 pm
Refracty Wed Nov 29, 2023 2:49 pm
Hello Paul,
will the release work with Rhino 8?
If not, when can we expect V8 releases.
Thank you
Nando
Refracty
Postby face_off » Wed Dec 06, 2023 1:55 am
face_off Wed Dec 06, 2023 1:55 am
Refracty wrote:Hello Paul,
Thank you
Nando
Hi Nando. The last time I checked, the plugin worked with Rhino8. Have you tried it?
Postby face_off » Mon Mar 04, 2024 4:29 am
face_off Mon Mar 04, 2024 4:29 am
I have updated the installers at the top of this thread with:
2023.1.2.138
Postby v-cube » Mon Mar 04, 2024 9:13 am
v-cube Mon Mar 04, 2024 9:13 am
thanks Paul!
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
v-cube
Return to Rhinoceros 3D
Users browsing this forum: No registered users and 20 guests
Sun Apr 28, 2024 6:48 am [ UTC ]
