RTX 4090 - Max load at 60 % with Octane
Forums: RTX 4090 - Max load at 60 % with Octane
Re: RTX 4090 - Max load at 60 % with Octane
Postby ssokol » Wed Feb 22, 2023 7:47 pm
ssokol Wed Feb 22, 2023 7:47 pm
The same problem here with RTX4090 and Standalone Octane... any help?
I did test with Octane bench 2020.1.5 and works ok 98%
ssokol
Postby ssokol » Thu Feb 23, 2023 7:50 am
ssokol Thu Feb 23, 2023 7:50 am
screens
GPU load jumps 50-70% ...
in Furmark test is correct 99%
furmark test.jpg (48.08 KiB) Viewed 3435 times
ssokol
Postby CANDITO » Thu Feb 23, 2023 10:39 pm
CANDITO Thu Feb 23, 2023 10:39 pm
Hi Lewis,
i just opened one of the demo scene that came with the last Octane standalone build
(Any scene with the new Photon tracing caustics)
When opening the old demo scenes present on the benchmark tool on standalone,
everything works fine at 98/100 %
Like there was something different between old scenes saved with previous Octane versions ?
It's quite weird, and it get worse when you use the PMC kernel, my card drops to 30/40 % max load.
I found that on the lightwave plugin, pushing the Parallel samples and Max tile samples to the max helps reaching 85/90 % on the card.
Olivier
CANDITO
Postby pixym » Thu Feb 23, 2023 10:47 pm
pixym Thu Feb 23, 2023 10:47 pm
Thanks for this tip.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - 32GB - 2 GTX 1080 TI - Win 10 64
NET RENDER : MB Biostar TB250-BTC Pro - Celeron 2C/2T - Open "Mining" Rig - 2 RTX 2080 TI - Win 7
pixym
Postby pixym » Tue Mar 07, 2023 2:24 pm
pixym Tue Mar 07, 2023 2:24 pm
Just discovered that : If you set Parallel Samples to 32 and Max Tile Samples to 64, you will get Max GPU Load…
pixym
Postby Pavlov » Fri Mar 08, 2024 12:41 am
Pavlov Fri Mar 08, 2024 12:41 am
I confirm the issue,
in large scenes IPR renders much faster than F10.
This is a major issue, since this thread is from past year i wonder if anyone found a solution.
Best
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
Pavlov
Previous
Return to Lightwave 3D
Users browsing this forum: No registered users and 5 guests
Fri May 03, 2024 12:31 am [ UTC ]
