Save depth map while rendering beauty pass
Forums: Save depth map while rendering beauty pass
Postby tombosschaert » Fri May 07, 2021 12:11 pm
tombosschaert Fri May 07, 2021 12:11 pm
Silly question perhaps, but it seemsto me that using the kernel so save out things like the Depth map, you have to render an entirely seperate run?
Is there way to do this while rendering using the other kernels? Or that's just how it is?
Problem with my scene is, it's not so much the render time, as the scene loading before each frame that cripples thje whole thing. So even if the render speed is high, a separate pass for a depth map will take hours.
tombosschaert
Re: Save depth map while rendering beauty pass
Postby juanjgon » Fri May 07, 2021 12:59 pm
juanjgon Fri May 07, 2021 12:59 pm
Why don't you use the info render passes to export this information? The info passes are rendered at the same time as the beauty pass.
juanjgon
Postby tombosschaert » Fri May 07, 2021 3:22 pm
tombosschaert Fri May 07, 2021 3:22 pm
I guess I am not aware of this function?
I'll take a look, thanks, might be just what I need!
tombosschaert
Postby juanjgon » Sat May 08, 2021 7:43 pm
juanjgon Sat May 08, 2021 7:43 pm
juanjgon
Return to Lightwave 3D
Who is online
Users browsing this forum: Bing [Bot] and 4 guests
Thu May 23, 2024 12:19 pm [ UTC ]
