How to render sequence image texture map with octane.
Forums: How to render sequence image texture map with octane.
Postby JerryJang » Thu Jun 22, 2017 12:50 am
JerryJang Thu Jun 22, 2017 12:50 am
I have a project need to render a man watching TV. and TV screen is texture mapped with sequence images, so it will show animation in the screen when rendered in LW.
But I find when I render it with octane,it only render the first image of sequence.
If I want to render the the sequence image.How could I do it in octane?Any one help?
JerryJang
Re: How to render sequence image texture map with octane.
Postby juanjgon » Thu Jun 22, 2017 8:34 am
juanjgon Thu Jun 22, 2017 8:34 am
The Octane plugin supports the textures sequence rendering with the same workflow used in LightWave, loading them as sequences in the image editor. The only issue is that if you are rendering in "update scene" mode, you must enable the option to update the materials in the render target root node options panel. The same happens in the IPR, you must enable the "Mat Upd" button to see the sequence while dragging the timeline.
juanjgon
Postby JerryJang » Mon Jun 26, 2017 4:55 am
JerryJang Mon Jun 26, 2017 4:55 am
Thank you for your reply,Problem resolved.^_^
JerryJang
Postby nico_cad » Wed Oct 11, 2023 7:54 am
nico_cad Wed Oct 11, 2023 7:54 am
excuse, map a sequence or a avi file? avi file not work in octane!! see it in native!
:D
nico_cad
Return to Lightwave 3D
Users browsing this forum: No registered users and 29 guests
Sat Apr 27, 2024 10:26 pm [ UTC ]
