DOCUMENTATION ADDENDUM: Background Plate
Forums: DOCUMENTATION ADDENDUM: Background Plate
Postby face_off » Tue Mar 22, 2022 11:58 pm
face_off Tue Mar 22, 2022 11:58 pm
Option 1 - Octane Visible Environment
Where a Modo "Environment Color" has Projection Type = Front Projection, add an Octane Visible Environment (https://docs.otoy.com/ModoH/ModoPluginManual.htm#Modo/VisibleEnvironment.htm) to the Environments in the Shader Tree, and add the above image to that mask.
Click the Visible Environment button on the Octane toolbar and enable Use RGB Color. Now drag the Visible Environment RGB Color onto the schematic and set the nodes up as follows (note the Octane Transform X Scale is set to -100%).
The Octane Viewport should now match the Modo render.
Option 2 - Compositor
Drag the Kernel->AOV Output Group property onto a workspace, and setup the compositor as follows. Turn on Kernel->Alpha Channel.
A sample .lxo using this approach is below.
aov.zip
(14.88 KiB) Downloaded 348 times
Re: DOCUMENTATION ADDENDUM: Background Plate
Postby Davve » Tue Aug 02, 2022 9:58 pm
Davve Tue Aug 02, 2022 9:58 pm
Hi paul!
Is this the way to render a backdrop image ? I've been having trouble with that previously.
When I tries this method the only result I get is the image on a sphere and not a plane projected from the camera...
D
Davve
Postby face_off » Wed Aug 03, 2022 11:21 pm
face_off Wed Aug 03, 2022 11:21 pm
Postby face_off » Wed Jan 11, 2023 2:31 am
face_off Wed Jan 11, 2023 2:31 am
I have updated the post at the top of this thread to include "Option 2 - Compositor".
Postby jwfvr » Thu Jan 12, 2023 8:30 pm
jwfvr Thu Jan 12, 2023 8:30 pm
thank you!
jwfvr
Return to Foundry Modo
Tue Jun 04, 2024 1:04 am [ UTC ]
