OctaneRender® 2022.1 RC 1 (updated 2022/11/3)
Forums: OctaneRender® 2022.1 RC 1 (updated 2022/11/3)
Re: OctaneRender® 2022.1 RC 1 [current 2022.1] updated 2022/11/3
Postby coilbook » Sat Nov 12, 2022 5:01 am
coilbook Sat Nov 12, 2022 5:01 am
haze wrote:I've added the Mac build. Here it is for convenience.
Octane X Prime 2022.1 RC 1 for macOS
Hi haze,
Can we please get an option how foggy is foreground and how fogy is background. I asked many times and I just get ignored. This will help a lot. Your company should hire a professional 3d artist who can tell you what your software is missing. And it needs a lot of things.
coilbook
Postby 3dworks » Sat Nov 12, 2022 3:29 pm
3dworks Sat Nov 12, 2022 3:29 pm
please when will we get a version with network rendering? waiting a long time for it...
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
3dworks
Postby Padi » Mon Nov 14, 2022 4:08 pm
Padi Mon Nov 14, 2022 4:08 pm
abstrax wrote:So just to be sure I understand: You open the application, the splash is shown, the splash disappears, the application window is opened and fully populated and then it crashes before you can do anything?
The application window is not populating. It just creates the window frame filled black and crashes immediately. The license gets locked and I need to open an older version to have it unlocked (or use unlocks on the website).
I will DM mojave now so you can look into the machine more closely.
Padi
Postby haze » Mon Nov 14, 2022 7:12 pm
haze Mon Nov 14, 2022 7:12 pm
Hi haze,
This is coming for 2023. Should be in the first beta release of it. By the way, my son loves watching your show.
haze
Postby haze » Mon Nov 14, 2022 7:18 pm
haze Mon Nov 14, 2022 7:18 pm
Thanks for your message. Could you PM me any details of your network rendering setup please? At the moment, Mixing Mac and CUDA nodes will not work, but this is going to be fixed in 2023.
haze
Postby Obizzz » Tue Nov 15, 2022 11:49 am
Obizzz Tue Nov 15, 2022 11:49 am
haze wrote:Hi all
  • Made coherent ratio less aggressive.
Happy rendering
Your OTOY team
Does this change the formula used in this calculator or should we still stick to those values if we want to be sure the coherent ratio is fully calculated to avoid flickering in animations? https://codepen.io/blastframe/full/mdmNmpa
Obizzz
Postby haze » Tue Nov 15, 2022 5:25 pm
haze Tue Nov 15, 2022 5:25 pm
Obizzz wrote:
haze wrote:Hi all
Happy rendering
Your OTOY team
To do a perfect conversion change this line
  let cr = (parseInt(max_samples)*0.35)/1024;
to this
  let cr = Math.pow((parseInt(max_samples)*0.35)/1024, 1.0/3.0);
For speed, try also increasing your parallel samples (unless you have already)
haze
Re: OctaneRender® 2022.1 RC 1 (updated 2022/11/3)
Postby john_otoy » Wed Nov 16, 2022 2:10 am
john_otoy Wed Nov 16, 2022 2:10 am
OctaneRender 2022.1 RC 2 has been released: viewtopic.php?f=33&t=80756
john_otoy
Previous
Return to Development Build Releases
Tue May 14, 2024 6:15 am [ UTC ]
