OctaneRender™ for Blender 2.23.2 - 8.6 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed the animation rendering bug: rendering of sequence always stopped after the frame having meshes with degenerate polygons or singular matrices. (thanks to aLeXXtoR for report)
  • A lot of improvements of the scene translation speed for single frames and animation sequences. Especially may be noticeable for animation of the scenes having lot of unpacked image textures (packed are always slower).
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v8.6 Linux (101.0MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
mac3d
Hello Jimstar, congratulations again for the work you do for the plugin on Blender ..
In the next release, you can enter the names of graphics cards? .. Even the Render priority is a fantastic tool .... Thanks
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
grimm
Looks like displacement is broken in this version. It doesn't matter what values I use for height or offset, the displacement never happens. I exported an OBJ of the scene and tested it in standalone and it works great.
grimm
Never mind, I found the problem. :oops:
Next version HERE.
kibbycabbit
grimm, please share with us what you did to fix it.
I'm trying to apply displacement. What's the proper node setup to apply a displacement to a (diffuse material) plane object?
System #1: Mac Pro Early 2009, 12GB ECC RAM, Display: GTX 750 Ti 2GB (Maxwell) + CUDA: GTX 980 4GB (Maxwell)
System #2: MacBook Pro /w Retina 15", 16GB RAM, GT 650M 1GB
System #3: PC Windows i9 6 cores, 16GB RAM, RTX 2080 SUPER 8GB
Return to “Blender”
