OctaneRender™ for Blender 2.23.2 - 8.4 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • New 2.23.2 engine.
  • New "Cube map" camera modes added: now you can render different faces of cube map separately.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v8.4 Linux (101.0MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
matrix2012
Hi
Have again the error message in CentOS 7 1503 .
./blender: /lib64/libcrypto.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /usr/local/OctaneBlender/lib/libOpenImageIO.so.1.4) :(
can someone help me here.
how can I with Centos 7 Octane for Blender from the git repository
page compiler.
A manual would be nice.
Please help
sorry for my english
matrix2012
Hi
can help me here any user?
Thanks in advance
matrix2012
System:
Centos 7 1503
mib2berlin
Hi, i think Blender is not officially supported to get build on CentOS.
You get information for other systems here:
http://wiki.blender.org/index.php/Dev:D ... ng_Blender
It is much easier to build Blender without Cycles, disable it for Blender for Octane.
You can open a new thread for it, may I and other users can help.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
matrix2012
Hi mib2berlin
Blender 2.74 without Octane is no problem running all well Cycles with Centos 7.
The problem is with Octane watch my first post.
openssl is installed what am I doing wrong?
Thanks for your help.
matrix2012
mib2berlin
Hi, I meant if you want to compile Blender Octane yourself it is a bit hard to get to work.
You have to set up you CentOS as build system.
If you never compiling software you need a few days to get into.
Cheers, mib
Next version HERE.
Return to “Blender”
