OctaneRender™ for Blender 2.23.2 - 8.4 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • New 2.23.2 engine.
  • New "Cube map" camera modes added: now you can render different faces of cube map separately.
Blender Octane Edition - 8.4 (2.74) (59.9MB autoinstaller file)
Octane Server - 2.23.2 - 8.4 (10.7MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.23.2 - 8.4 (9.2MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
aLeXXtoR
Thank you! :)
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
Garquitectos
Many thanks!
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
voon
Octane Server has an issue in this release, it does not exit properly. i can consistently reproduce it.
If I start it (even without blender), it sits there, using 40 MB of ram ... so thats fine. If I rightclick the icon in the windows miniicon tray, it does not shut down properly ... it starts growing extremely quickly in memory, eventually using up all memory within seconds (I shot it down with windows task bar at 25 GB+). There's some sort of massive memory leak instead of shutting down after a right click.
voon
Did you have the same issue with 8.3 version?
voon
Hi Jim .. I quickly installed 8.3 to check and it does not happen there .. it's an 8.4 issue.
voon wrote:Hi Jim .. I quickly installed 8.3 to check and it does not happen there .. it's an 8.4 issue.
Then it looks like not the plugin issue... As the only change in this OctaneServer version made - it was just built with the last 2.23.2 Octane SDK. No code changes in server were made, only Blender edition code was improved to integrate the new cube map camera modes of 2.23.2 SDK.
I will check it tomorrow, thank you for report.
aufwind
When adding a texture to the world settings in the node editor
I get a script error.
HDR background is rendering without any problem though
Next version HERE.
Return to “Blender”
