OctaneRender™ for Blender 2.21.1 - 7.5 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed nodegraph bug affected some nodes interconnections (thanks MattRM).
  • Fixed the emission nodes inconsistency.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.5 Linux (96.3MB autoinstaller file)
00Ghz
// When I try to open it it stays for a second then it closes. Am I doing anything wrong? - Restarted linux and it opens now
But how do I select octane render as a render engine? - fixed - enable Haddon just like in win
However last part is most challenging. What driver version I need to make blender octane version see the GPU's? And where exactly I enable the server? I tried typing the command written here in the terminal but doesn't seem to do anything. On windows this was easy :)
HDRI Editor for Blender : Your own HDRI Studio at an affordable price.
https://gum.co/HDRIEditor
mib2berlin
Sometimes you have to enable Octane in Addons again.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
00Ghz
mib2berlin wrote:Sometimes you have to enable Octane in Addons again.
Cheers, mib
great thanks, what about the last part? this linux thing is not easy...
Next version HERE.
Return to “Blender”
