OctaneRender™ for Blender 2.21.1 - 7.1 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Merged with Blender 2.73.
  • Switched to 2.21.1 engine.
  • Mute function for Octane nodes is implemented (select node, press "M").
  • Now you can choose in render settings what for HDR you need to render - tonemapped or not.
  • Added Octane render layers. You can set the layer ID in the mesh's Octane properties and enable layers in Octane Layers properties. Global mesh is always on layer "1".
  • Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
  • Added Octane Noise texture.
  • Added "Affect alpha" attribute to specular material.
  • Removed "Keep environment" attribute from kernels.
  • Removed "Start samples" attribute from passes settings.
  • Fixed the camera rotation bug.
  • Fixed imager presets bug.
  • Minor fixes...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.1 Linux (96.2MB autoinstaller file)
kaiwas
Thnx!
But... :geek:
kaiwas
Looks like some process already uses the ports, perhaps another OctaneServer process...
You can check who uses it by "lsof -i", something like this:
lsof -i | grep 5130
kaiwas
thank you! Ostanserver completed the process in Task Manager. Everything works.
grimm
Excellent! Any chance for the git repo to be updated? Thanks,
Jason
grimm
I compiled the plugin and it appeared to work, no errors at least. But when I try to turn rendering on in the viewport or for a full render I get a huge list of linker errors.
Octane: ERROR: Tried to access pin via an invalid ID P_RENDER_PASS_POST_PROCESSING (155)
Tried to access null node pin
Node type 86 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7fac38087ca0)
Tried to access pin via an invalid ID P_FOCAL_DEPTH (49)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7fac38087ca0)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7fac38087ca0)
This just with the default cube and no other changes. I have made sure that I'm not trying to do render passes, etc. Maybe it's something in my config that is passed on to this new version from the old? Let me know if you would like the full error list, it's very long.
Jason
Synthercat
After I went to Mint 17.1 all works fine like a charm! No lib links any more, no nothing! :D
(Well, except the blacklisting of neuvau and the installemnt of nVidia drivers from their site)
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Next version HERE.
Return to “Blender”
