OctaneRender™ for Blender 1.55 - 5.2 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed bug: crash on Linux during changing of some material attributes.
  • Fixed bug: wrong dispersion coefficient loaded into server from Specular material.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v5.2 Linux (111MB autoinstaller file)
grimm
Thanks Jim,
Your fix worked, yay!
Jason
mib2berlin
Yep, work all fine on first tests, thanks.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Synthercat
Doesn't crash anymore, refresh also seem faster but not as fast as 4.9 version. Is there anything you can do about it Jimstar?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Next version HERE.
Return to “Blender”
