OctaneRender™ for Blender 1.20.2 - 2.6 beta Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Added "Subframe Motion Blur" feature. So far the "Movable proxy" objects feature is not fully implemented, so this motion blur will work not with the full possible speed. After "Movable proxy" feature will be implemented in next versions - this motion blur feature will become a lot faster...
  • Added "Interpolated vertex normals" info-channel type.
  • Minor improvements and bug fixes...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v2.6 beta Linux (128MB autoinstaller file)
grimm
This version is working well for me, although OctaneServer still crashes on me with the same error as before. I haven't had the same situation that happened before where OctaneServer didn't crash but it also wouldn't update the image as it was rendering until max samples was hit. I left that one running for more than a day and it didn't crash, don't know if that helps or not. Usually OctaneServer will crash on me from between a half an hour to 2 hours of use. There doesn't appear to be a single cause as I have had it crash while using Blender, or just leaving it running.
Next version HERE.;)
Return to “Blender”
