***** NEW ICON SET DESIGN ***
julesvm wrote:Hey - share the new UI with me and I can update the new icons. Working on it today.
I'll send soon. Thanks
julesvm
Great thanks - one request, is it possible to make all icons .png? Right now you're using a mix of .jpg .tff. Possible?
yes, i'll change all to png before sending.
julesvm
I'm also creating different icons for each type of light. So I need the ui to reference different files for each icon.
thanks
julesvm wrote:I'm also creating different icons for each type of light. So I need the ui to reference different files for each icon.
thanks
Thanks julesvm, there is the zip. Lights are setted as different icons as you says. Also i can send a test version. Are you on Macos R15? Is it possible to make 48x48 or 64x64 for command icons?
res.zip
(612.73 KiB) Downloaded 320 times
julesvm
thanks
Yeah, I'm mac-os r16 (but I've been using your r15 release and it works).
Yeah, 64x64 and 48.x48 are no problem
Hi all,
there is a preview version before doing a release. Please see the improvements and drop some notes here.
2.12.2-test2 Windows version (R13-R16)
http://render.otoy.com/customerdownload ... t2-win.zip
2.12.2-test2 MacOsX version (R14-R15)
http://render.otoy.com/customerdownload ... Macosx.zip
pBarrelas
Those Icons are cool and I prefer to have the Octane Dialog attached to the LV, as you have now. I had a custom layout set that way.
The blue color on the Pause button isn't much visible. While in pause mode it could have the same color as the stop button.
I miss the node graph button, though!
The Syncronization on geo. updates, doesn't seem yo do what I suppose it should. I'm moving a simple cube around and it's not updating. I need to Restart a new render.
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
pbarrelas, all is possible. check guide menu to switch menu and icons. also just use lv, without dialog. for updates, it's working very good here. check please again
pBarrelas
aoktar wrote:pbarrelas, all is possible. check guide menu to switch menu and icons. also just use lv, without dialog. for updates, it's working very good here. check please again
I'm using only LV now. I just mentioned that with 2.12.1 I was using the same setup but had to create a custom layout. Now its a lot more practical.
Sorry but the geometry really doesn't update while moving it and turning the menu and icons on/off in the GUI menu, doesn't work at all. I'm on R16, by the way.
